Wastegate Suggestions
Old Jan 20, 2004 | 12:24 PM
  #26
integranator's Avatar
He shouldn't be using the top part of the Wastegate unless he's planning on running an electronic wastegate that requires both ports. You might clear the hood if ya don't use the top nipple!! Good luck tho mayn!
Old Jan 20, 2004 | 12:27 PM
  #27
Default Re: (b18bEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bEG &raquo;</TD></TR><TR><TD CLASS="quote">powersteering is overrated</TD></TR></TABLE>
LOL
Old Jan 20, 2004 | 01:06 PM
  #28
Ri5e's Avatar
Default Re: (integranator)
Are you using a boost controller? If you're not, just remove that top nipple. If you are, remove that top nipple and replace it with a standard brass one. Might not look pretty but it works
Old Feb 10, 2004 | 07:22 PM
  #29
Muckman's Avatar
Moderator in Chief
Default Re: (CRV Monster)
I will be using the top fiting for a EBC. The Elbo makes a dumptube impossible. Im screwed either way. Hopefully I can get enough clearance from cutting the hood frame.
Old Feb 10, 2004 | 07:26 PM
  #30
redboost10's Avatar
Default Re: (Muckman)
if you cut the hood frame and put the wg on standing up, if that motor tilts back when you take off your gonna have a dent in your hood arent you?
Old Feb 10, 2004 | 08:00 PM
  #31
DownBoyDown's Avatar
Default Re: Wastegate Suggestions (brryder)
[QUOTE=brryder]here is the pics
When not using the top port, is it bad to leave it open like that? Or is it better to find a bolt that will close up the hole?
Old Feb 22, 2004 | 08:13 PM
  #32
ChillOutWayne's Avatar
Default Re: Wastegate Suggestions (DownBoyDown)
ok quick question, and after quickly readin i couldnt find this answer, i got a 94 GSR and i bought a Revhard mani and im getting the 38mm WG, if im not running a boost controller on top can i do standard vertical mount straight up without fitment problems?
hbyrd8701
Apr 11, 2009 11:47 AM
Accurate GS-R
Oct 17, 2004 07:47 PM
VtecAdil
Oct 14, 2004 10:44 AM
BobGnarly
Aug 9, 2004 11:13 AM
bo0sted
Jul 5, 2004 06:50 AM
