Which wastegate spring to run with electronic boost controller
Old Feb 20, 2008 | 06:54 PM
95dc2teg's Avatar
Default Which wastegate spring to run with electronic boost controller
I am almost done with my build and have a little dilemma that i am unsure of. I am running a precision sc6176e on my built block and want to run about 500whp. (i have all supporting mods for this goal).
I have two wastegate springs for my tial 44mm. I have a small green which is 6lbs and a large blue which is 13lbs. Now will i be able to run the 6lb spring and be able to turn up the boost to lets say 20+lbs? If so that would be great because i dont want to run the 13lb spring and that being the lowest psi i could run. What do you guys think??
hopefully i got my point across
Old Feb 20, 2008 | 07:02 PM
drumking15's Avatar
usually the rule of thumb is w/ a boost controller you can run 2x the spring rate
for ex...6 psi spring = 12-14psi on a controller
in your case if be lookin for a 8-9psi spring...so u can run 8-9 wg'd and then run 20ish on the controller
Old Feb 20, 2008 | 07:11 PM
totsie7944's Avatar
Default Re: Which wastegate spring to run with electronic boost controller (95dc2teg)
You can pretty much double spring rates. And with a good electronic boost controller like the apexi AVCR, etc it will usually maintain boost consistency pretty well. If I were you I'd just rock a 8lb spring for street and track. Unless you've got a all out drag car, a 8lb spring is pretty much best of everything haha
Old Feb 20, 2008 | 07:16 PM
95dc2teg's Avatar
Default Re: Which wastegate spring to run with electronic boost controller (totsie7944)
well i have a aem tru boost ebc, so wil that be able to boost more than 2x the spring rate? I just dont want to run 13lbs on the street with the sc61 at all times i would like to run like 350 -400 on the street with pump and 460-500+ on race at the track....
Old Feb 20, 2008 | 11:51 PM
hellakapps's Avatar
13 is a bit much for min. i like 10lb spring for the lowest setting 6 is nothing
Garage 808 Hatch
Dec 4, 2006 08:22 PM
swappedcx
Jul 16, 2006 07:00 PM
dunkd
Feb 3, 2005 11:45 AM
LSEGHATCH
Dec 15, 2004 10:51 PM
wonny
May 30, 2002 03:18 PM
