wastegate spring question?
Old Sep 3, 2007 | 06:02 PM
perseverance's Avatar
Default wastegate spring question?
i have a innovative minigate waste gate, i think it's 38mm... and it giving me about 6lbs of boost. i want to up the boost but don't have the money for a boost controller. what spring can i get to up the boost to about 10? my motor is built for it, but it's been tamed.... now i plan on upping the numbers a lil. can i use a different waste gate spring? i've been searching and can't find any innovative waste gate springs. thx for the help H-T!!!!
Old Sep 3, 2007 | 06:23 PM
turbosol18's Avatar
Default Re: wastegate spring question? (perseverance)
not sure about the innovative minigate 38mm but i got a tial 38mm and the springs are colored and each color give different psi ranges
but if the springs are the same you want to go with the large yellow spring which gives 10psi/0.7 bar
Old Sep 3, 2007 | 07:53 PM
lovey408's Avatar
Default Re: wastegate spring question? (turbosol18)
i knw u can get a boost controller from ebay and stuff and i heard of people using it and works fine for them.. also u wuld need to re-tune it as well with more booost right?
Old Sep 3, 2007 | 08:54 PM
gsr x civic's Avatar
Default Re: wastegate spring question? (lovey408)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovey408 &raquo;</TD></TR><TR><TD CLASS="quote"> u wuld need to re-tune it as well with more booost right?</TD></TR></TABLE>
yeah.
you can just go with a boost controller to up the boost, but make sure you have a boost gauge so you know what psi you're at when you turn it up. and when you do, don't rip on it til you get it tuned.
RTW DC2R
Mar 24, 2006 06:33 PM
Jwbetley
Sep 17, 2005 11:00 AM
redboost10
Nov 16, 2003 02:07 PM
shingles
Jan 24, 2003 01:58 AM
