Wastegate Spring Question
Old Dec 6, 2006 | 04:39 PM
building boost's Avatar
Default Wastegate Spring Question
I am currently running a turbosmart 48mm wg. I have two springs in the wastegate giving me a low boost of 18psi. My high boost is 26psi. I am now retuning. The question I have is will I be able to take the turbo up to 40psi with the 18psi springs in the wastegate? Or will I have to upgrade to 20 psi or greater? I am using an AEM 5 bar map sensor with hondata s200. I dont want to come out the hole with 20+ psi, that's why I want to know if there is anyway I can keep my 18psi springs and still boost up to 40 psi.Thanks for the input.
Old Dec 6, 2006 | 05:59 PM
wrx'n you's Avatar
Default Re: Wastegate Spring Question (building boost)
i've been told that its all in the boost controller. if u have a nice quality one it'll be alright but if u have a shitty homemade one or something, u'll start having boost problems
Old Dec 6, 2006 | 06:53 PM
im using a turbosmart dual stage.
Old Dec 6, 2006 | 07:16 PM
Mugencrxsir1's Avatar
Default Re: (building boost)
The general word of advise for wastegate springs is that it should be half of your high boost. So I run between 16-20psi on my set-up, and I have a 9-11lbs spring. So your ~18lbs spring is perfect to run 40psi on your current boost controller, but I do prefer an electronic boost controller. But again your set-up will work just fine the way you have it!
Old Dec 6, 2006 | 09:04 PM
thanks. i just want to make sure i will be able to take it to 40psi if the need arises. i am paying for dyno time and i don't wanna get stuck because of boost creep etc.
Old Dec 7, 2006 | 12:38 PM
anybody else?
Old Dec 7, 2006 | 12:51 PM
mike1114's Avatar
again, more speculation....but I have heard that most springs will handle about 3 times the pressure before they start failing/giving issues.
18*3=54psi so you should be ok.
Although, I do have a 5psi spring and I rock it up to 24psi!!
mitchell_2kSiR
Mar 11, 2008 09:37 AM
zman
Feb 13, 2006 06:24 PM
Taikonaut
Oct 29, 2003 11:34 AM
01ITR#700
Jun 22, 2003 10:01 AM
shingles
Jan 24, 2003 01:58 AM
