WASTEGATE SPRING, NEEDED???
Old Mar 1, 2004 | 08:06 PM
Harassing Herbs's Avatar
Default WASTEGATE SPRING, NEEDED???
Just put turbo set up on my car. i have a Manual Boost Controler and a tial 35 MM wastegate. i know that the boost controler can not lower the boost that what the spring is set for. so if i run the MBC and no spring in the wastegate would i be able to set the boost to what ever i want? or wiould the waste gate not work at all??
Old Mar 1, 2004 | 08:08 PM
b16ahybrid's Avatar
Default Re: WASTEGATE SPRING, NEEDED??? (Harassing Herbs)
LOL, yeah you would have -0- boost, the wastegate would be open.
Your best bet is to get a .35bar spring and raise the boost from there.
Old Mar 1, 2004 | 08:12 PM
Default Re: WASTEGATE SPRING, NEEDED??? (b16ahybrid)
no boost even with turning up the MBC?
Old Mar 1, 2004 | 08:31 PM
b16ahybrid's Avatar
If you have no spring then there is nothing to keep the piston closed.
You can crank the boost controller up to 10million psi, it still won't matter because the exhaust gasses will open the wastegate.
oMek
Feb 29, 2004 09:09 PM
shingles
Jan 24, 2003 01:58 AM
DOHCarp
Jun 29, 2002 11:30 AM
wonny
May 30, 2002 03:18 PM
DIRep972
Aug 18, 2001 03:34 AM
