wastegate spring 10psi??
hello, im getting done my setup:
stock b16a
60-1 turbo
log manifold
tial 38mm wastegate
rc 750s
walbro fuel pump
I want to run 10psi but dont know if i should just use the 0.7 bar spring on the wastegate. what do you guys say? remember its a stock motor and i dont want the boost spiking.
help . thank you.
stock b16a
60-1 turbo
log manifold
tial 38mm wastegate
rc 750s
walbro fuel pump
help . thank you.
take the i want to run 10psi out of your head and come up with a power goal
with that turbo youll make 300-375whp at 10-14psi easy
you gonna need a 3 bar map sensor cuz 10psi is kinda push'n the stock one
and what ems your using
tuning is going to be on chrome... i just say 10psi because that is on the safe side.
i dont think think 14psi is going to be safe, but the motor could last because its not my daily driver I only drive it to the track and back.
I will get an omnipower 4 bar map sensor because there is no wiring required.
300 / 320 whp would be my goal for now.
Redwidow
Feb 24, 2007 10:38 AM
GSRswapandslow.
Jun 23, 2004 12:24 AM
