Tial 44mm WG .6bar & AVCR Whats the most PSI I can tune up to?
I searched and could not come up with a 100% answer to my question.
I have a GM 3 bar map and all the goodies. Just need to know if I need another spring to add into my WG. I want to tune up to 28-30+ psi if possible. Thanks for your input in advance.
Servion when you avaliable
Re: Tial 44mm WG .6bar & AVCR Whats the most PSI I can tune up to? (Redwidow)
if im not mistaken the gm 3 bar will only read up to 32psi. someone correct me if i am wrong
Re: (Snafubmx234)
You'll only get about 16-18psi with that small wastegate spring before the spring will start to float. Normally you can only go double your wastegate spring psi.
Re: (RacerXI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI »</TD></TR><TR><TD CLASS="quote">You'll only get about 16-18psi with that small wastegate spring before the spring will start to float. Normally you can only go double your wastegate spring psi. </TD></TR></TABLE>
thats not true you can usally get about 3 times the amount out of the spring... a 3bar will read 29psi
Mr. Badwrench
Re: Tial 44mm WG .6bar & AVCR Whats the most PSI I can tune up to? (0554)
i remember reading this somewhere. either synapse or tial.
you can go 2-3 x the spring pressure.
if you are goin higher than that, you will have inconsistencies. and will need a stiffer spring. i am going to look into that a little more now because i want to run alot more boost than that this year.
and brett is correct on the 3 bar, although i thought it was 27-28, but yeah.
1 Post
Re: Tial 44mm WG .6bar & AVCR Whats the most PSI I can tune up to? (boostedcivicsir)
a 3 bar map sensor will read up to 29psi
generally you dont want to run more than double the wastegate spring pressure
Re: Tial 44mm WG .6bar & AVCR Whats the most PSI I can tune up to? (riceball777)
thanks for the info guys looks like i'd be better off with a 1 bar spring
if it a street car if so i wouldnt run a bar spring... 14 psi can yield a good amount of power on most car. nad that will turn into tire roasting which is no fun. you will be more happy with a 7psi spring...
Re: Tial 44mm WG .6bar & AVCR Whats the most PSI I can tune up to? (vaporboy12)
fwiw, you can run alot more boost than your map sensor will read. just that your "fuel" will only go up to the last boost column...
Re: Tial 44mm WG .6bar & AVCR Whats the most PSI I can tune up to? (dturbocivic)
yeah but thats not the best way to do things. it may work but i wouldnt do it
PGT Driver
04-13-2004 07:54 PM
