wastegate for silver surfer
Old Jul 7, 2012 | 10:27 AM
BAp_mobile's Avatar
Default wastegate for silver surfer
What wastegate would I need for my set up.
.t3/t04 silver surfer .63AR - 350-400hp
what spring, psi, bar??
Old Jul 7, 2012 | 10:37 AM
dpetro1's Avatar
Default Re: wastegate for silver surfer
im sure a standard 38mm (or mvs) would work fine. the spring just determines the minimum boost level. most likely you will want to get a boost controller to turn it up to the desired level to reach your hp goal.
what manifold are you using? what wg flange does it have?
Old Jul 7, 2012 | 12:49 PM
BAp_mobile's Avatar
I have I peak boost ac/ps ramhorn manifold with a 44 mm vband wastegate option
Old Jul 7, 2012 | 12:50 PM
BAp_mobile's Avatar
Thus I kno ill be getting a 44mm but still spring psi and bar need to be determined
Old Jul 7, 2012 | 01:37 PM
dpetro1's Avatar
psi and bar are just different units of the same measurement. 1bar = 14.5psi
do you plan to use a boost controller or are you trying to achieve the desired boost pressure with just the wg spring pressure?
the highest single spring you can get is .9 bar (13.05psi). after that you need to start using multiple springs to achieve higher psi
spring pressure chart
http://www.tialmedia.com/documents/w3_tial_44_sp.pdf
blackeg
Mar 18, 2008 09:31 PM
rbecue
Jun 16, 2005 03:03 AM
LSEGHATCH
Dec 15, 2004 10:51 PM
jure
May 6, 2004 02:32 PM
Taikonaut
Oct 29, 2003 11:34 AM
