Wastegate releasing pressure at idle
Old 09-11-2009, 12:35 PM
kauai96's Avatar
Icon5 Wastegate releasing pressure at idle
Ok it all started with my BOV no releasing pressure. so i went checked all my vacuum they all seem good. so now i was thinking what else it could be. i see that my wastegate is letting pressure out at idle and all the way trought the RPM's is this normal? any help?
Old 09-11-2009, 12:40 PM
bigD's Avatar
Default Re: Wastegate releasing pressure at idle
make sure the fire ring on the wg is installed right.
Old 09-11-2009, 12:55 PM
kauai96's Avatar
ok ok ill check it after work. also i switched the vacuum soucre yesterday from my distrbution block to the nipple off the turbo and my car just died out? should that happen? i heard you could hook it up to that source.
Old 09-11-2009, 02:16 PM
90civichbsi's Avatar
It shouldn't, thats where mine has been plugged in since day one. Unless you didnt plug the nipple on the distribution block
what kind of wastegate is it?
Old 09-11-2009, 02:35 PM
Moderator in Chief
Muckman's Avatar
My money is on the fire ring.
Old 09-11-2009, 03:55 PM
kauai96's Avatar
no i do not have the turbo nipple teed off in to the distrubution block if thats what you mean? thats what i thought. but when i started the car after switching the lines back the IAC was all off giving the fluxuating idle. fire ring? what is that. the ring around the vavle?
Old 09-11-2009, 03:56 PM
kauai96's Avatar
i have a cheap ebay waste gate. i kinda think that may have somthing to do with it
Old 09-11-2009, 03:58 PM
kauai96's Avatar
is it that the gasket? the fire ring?
Key Enzyme
03-27-2013 01:31 PM
turbodailydan
07-30-2009 05:13 AM
shortyz
02-03-2009 04:34 PM
fipracing_com
08-15-2004 12:55 AM
baddassduramax
11-15-2003 09:52 AM
Quick Reply: Wastegate releasing pressure at idle
