wastegate question?
Old Nov 28, 2007 | 01:54 AM
ef8_eg6's Avatar
Default wastegate question?
would a tial 38mm be able to handle 18psi..and if yes with was size spring?
Old Nov 28, 2007 | 02:28 AM
integlspwr2k's Avatar
Default Re: wastegate question? (ef8_eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8_eg6 &raquo;</TD></TR><TR><TD CLASS="quote">would a tial 38mm be able to handle 18psi..and if yes with was size spring?</TD></TR></TABLE>
i would runa 1bar spring and use a boost controller to bump it up to 18psi.
Old Nov 28, 2007 | 03:20 AM
boostedcivicsir's Avatar
Mr. Badwrench
is that the highest you plan on running? if you plan on running less than 15 psi then a 1 bar isnt for you. .7 .8 bar and adjust up from there, but if 18 is the lowest you plan on running, a 1bar is great. (44mm with a 1 bar here 34 psi.)
Old Nov 28, 2007 | 03:22 AM
non-VTEC's Avatar
Default Re: wastegate question? (integlspwr2k)
depending on the boost controller you use the 38mm will hold hold 18psi no problem..
im using a 3.6psi spring allong with a apexi avcr and it holds 17psi solid
aleks77
Apr 8, 2007 02:09 PM
vr6chris
May 24, 2004 12:49 AM
jure
May 6, 2004 02:32 PM
Cyber ITR
Jan 19, 2004 03:38 AM
