Wastegate problems help!
Old Aug 7, 2007 | 07:57 PM
Insperation's Avatar
Default Wastegate problems help!
Ok I know the sound of a open dump tube wastegate sounds. But for some reason mine sounds wierd. It sounds like a crazy fast valve tapping. My motor seems fine. No valve tapping there. Its just when I get on it, it makes that wierd sound. Bad springs you guys think? Bad Wastegate? Am using a Tial 38mm btw boosting only 6psi. Thanks for the help.
Old Aug 7, 2007 | 10:59 PM
SlowhatchSi's Avatar
Default Re: Wastegate problems help! (Insperation)
maybe what you're hearing is your engine pinging?
Old Aug 8, 2007 | 07:36 AM
Default Re: Wastegate problems help! (SlowhatchSi)
Nope, check everything out. no leaks or smoke.
Old Aug 8, 2007 | 07:51 AM
93supercoupe's Avatar
make a video, and link us.
If its the niose i am thinkiing of, its normal, they tend to sound like that on lower boost levels.
But there is no way to tell until i hear it.
Old Aug 8, 2007 | 09:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
stupid question,
drag kit? mine sounded the same way.
just up the boost, the gate wont open as far making less noise. he hee. j/k
Old Aug 8, 2007 | 09:08 AM
DCxMagus's Avatar
nothing is wrong with your wastegate, if you can hold a certain amount of boost that you have it set for then your wastegate is doing it's job correctly.
if it was openning and closing you would have boost spikes
if it was bad and no openning you would be overboosting
if it was staying open all the time you would probably only boost like 2-3 PSI in the upper rpm ranges.
all wastegates sound different on differ cars and motors at different PSI.
sound isn't the best way to diagnose a problem unless it's effecting your performance then I wouldn't worry about it
Old Aug 9, 2007 | 02:22 PM
Default Re: Wastegate problems help! (93supercoupe)
Thats what most of my buddies was saying. Its because am only runing 5psi
supabang
Aug 19, 2007 08:12 AM
opto_isolator
Sep 12, 2004 08:46 PM
abeaujuin
Aug 2, 2004 06:03 PM
B20-T
Feb 18, 2003 01:05 PM
underpressure02
Nov 5, 2002 05:38 PM
