wastegate issue?
Old Jan 15, 2018 | 02:02 PM
Boosted00's Avatar
Default wastegate issue?
So I put together a b20vtec and put a turbonetics turbo, 38mm tial wastegate ect.. Went to get it tuned last weekend and on the dyno the wastegate has a 14psi spring, and it opens at 14psi, but as soon as it opens the boost drops to 9psi and stays at 9 the whole time the wastegate is open, shouldn't it regulate the boost to stay at 14psi even with it open? We put a boost controller on to see if that would help at all, set the boost to 17psi, when we hit 17psi the wastegate opens as it should be then the boost drops back off to 9-10 psi as wastegate is open. I don't think this is normal, the tuner thinks its a bad manifold design but I believe it to be the wastegate having issues?
Old Jan 15, 2018 | 02:25 PM
2kdrift's Avatar
Default Re: wastegate issue?
It holds at the target pressure..once it goes below 14psi the spring is supposed to close the valve in the Watergate. I would lean more toards wastegate/spring or even boost leaks then the manifold itself
where is your boost reference?
also what manifold? Which turbo? What motor?
the more information you give us the better we can help
Old Jan 15, 2018 | 03:33 PM
Boosted00's Avatar
manifold i bought used, unknown brand, turbo is a Turbonetics 57 trim, 63ar, motor is a b20b with a b16 head. Boost reference is straight from the turbo. Could the greddy type rs bov be causing issues as well? It was set to a soft setting, i was wondering if when wastegate was opening at 14psi if the pressure differential was causing the bov to open some?
Old Jan 15, 2018 | 04:49 PM
2kdrift's Avatar
What is the manifold design?
boost reference should be at the intake manifold not the turbo, there can be pressure losses along the intercooler and piping so it may read higher at the turbo compared to what is actually happening at the intake manifold.
a quick search found that bov could be to soft and cause this issue aswell
Old Jan 15, 2018 | 05:01 PM
Boosted00's Avatar
Ok thanks for the help, should i just plug the nipple at the turbo then and run the wastegate reference from the intake manifold?
Old Jan 15, 2018 | 05:15 PM
2kdrift's Avatar
Yes.
Also take an air compressor and boost your wastegate to verify it opens and shuts at the proper times
while your at it use it to boost leak test to see if anything is leaking at 14 psi
Old Jan 15, 2018 | 05:19 PM
Boosted00's Avatar
Originally Posted by 2kdrift
Yes.
Here is a picture of the manifold
Old Jan 16, 2018 | 06:53 AM
Balor_Gr's Avatar
Does it gradually fall as rpm raises or sudden drop of boost ?
Old Jan 16, 2018 | 06:54 AM
Boosted00's Avatar
drops pretty fast to 9 psi, its alamaost like thebwastegate is opening all the way up and no closing fast enough to sustain 14psi.
Old Jan 16, 2018 | 07:31 AM
sneakypete's Avatar
Those manifolds are notorious for having problems controlling boost. Look where the wastegate placement is, the exhaust has to make a 120 degree turn to exit out of the wastegate. My advice would be to get a new manifold with a better wastegate placement, plus those manifolds are also know for cracking unless it has been braced. I would get a ramhorn manifold or a cast iron manifold with the wastegate placement in the middle part of the manifold. Don't get a mini ram manifold, you will have oil return issues since the turbo sits so low.
Old Jan 16, 2018 | 09:54 AM
2kdrift's Avatar
Typically those manifolds boost creep rather then lose boost. As far as cracking really depends on who made the manifold if its an ebay version then yes they crack mini rams made with good materials not so much.
Is that Genuine Tial or knockoff? If its a knockoff I would not trust it at all, if its genuine I almost wouldnt even bother testing it as it looks new. From your description about "not closing fast enough" sounds like a knockoff, a genuine Tial would never do this...but you need to test its operation at this point
double check your vband connection is tight looks to be on the looser side in this pic The dumptube portion looks extremely loose...which wouldnt cause this issue but would still be an exaust leak, just dont over tighten, Also looks like you are using Intake manifold studs on the exhaust side Make sure everything is tight, Personally I use OEM studs and OEM exaust nuts. Make sure those are nice and snug aswell
I also recommend getting a 4 port Boost controller to utilize the top port
But again I stand by my previous post about testing operation of wastegate, and boost leak test. Plenty of information on youtube about how to do this all you need is an air compressor. If you need further assistance I will be happy to help
Below is a picture of how tight my Tial vband clamp is, for reference only do not overtighten
Old Jan 17, 2018 | 11:09 AM
Dark_Teg's Avatar
I think you have a massive exhaust leak pre-turbo. Cracked/broke manifold, loosened turbo to manifold bolts etc...
Old Jan 17, 2018 | 02:23 PM
Boosted00's Avatar
Thanks guys its going to warm up a little this weekend and I will double check everything.
Old Jan 18, 2018 | 02:29 AM
Balor_Gr's Avatar
Are you sure youre not using a 9lbs spring that spikes to 14 ?
Old Jan 18, 2018 | 08:49 AM
Dark_Teg's Avatar
That would totally explain it wouldnt it. I bet your right.
Old Jan 18, 2018 | 04:38 PM
Boosted00's Avatar
the wastegate supposedly has a 14psi spring, im going to hook a regulator up this weekend and test and see where its actually opening. What doesnt make since though is even with a boost controller, it would open later but still drop to 9-10 psi. guess we will know more this weekend. I did however check all the manifold bolts and was able to tighten everyone of them. I appreciate all the help from you guys and I will keep pecking away at it. I will keep everyone posted.
Old Jan 18, 2018 | 05:14 PM
ls joker's Avatar
Loved
Did you see any carbon buildup blowout
Old Jan 18, 2018 | 05:47 PM
2kdrift's Avatar
You sure it still has the fire ring? Pretty common for people to forget about it
Old Jan 19, 2018 | 01:51 PM
Boosted00's Avatar
ok guys put together a regulator ,wastegate has a 14psi spring, so along with finding bov set very loose, exhaust manifold bolts not very tight, i found the the plugs on the wastegate was leaking some as well. I sealed them up and ill test again shortly.
DelSolMarine
Apr 17, 2022 10:21 AM
alperx
Jan 24, 2012 12:22 PM
richboi
Apr 15, 2007 07:46 PM
turbodan4
Mar 7, 2006 09:09 PM
turbo se
Jun 13, 2003 11:33 AM
