wastegate internal or external
Old Oct 27, 2005 | 09:20 PM
Turbo_y8's Avatar
Default wastegate internal or external
alright ive got different responses to both, what are the pro and cons of both internal and external wastegates,
any sounds clips, does one sound better than the other but more importantly what doe s abetter job
thanx
Old Oct 28, 2005 | 04:27 AM
green_GSR's Avatar
Default Re: wastegate internal or external (tuck'd98)
Internal wastegate is a simpler design, so less piping is involved and you won't have to buy an external wastegate. However, it is much harder to control boost (boost drop, boost spike, fluctuating boost, etc.) than the external one.
With an external wastegate, there is more piping involved. You would also have to buy an exteranl wastegate (which can cost you big $$$ if you want nice ones). You can also make more power with an external wastegate if you run a dumptube setup. Boost control is much better than the internal wastegate.
g2daturbo
Jun 2, 2008 03:45 AM
60-1
Mar 18, 2004 11:30 PM
MayhemSi
Sep 6, 2003 11:47 AM
VTEC-DA
Sep 13, 2002 02:01 PM
whagkangmakulet
Oct 1, 2001 11:34 AM
