Wastegate Problem
Old Jan 30, 2004 | 10:01 AM
boostsohfast's Avatar
Default Wastegate Problem
I'll let the pictures speak for themselves:
It's a tial 35mm on a friend's car. Is this wastegate shot or can that piece be replaced? The turbo will only spool like 3 psi even with the vacuum line to the wastegate disconnected.
Old Jan 30, 2004 | 04:01 PM
Default Re: Wastegate Problem (boostsohfast)
ttt! someone knows about this.
Old Jan 30, 2004 | 04:03 PM
B18EG6's Avatar
is that orange piece melted together?... i cant really tell
Old Jan 30, 2004 | 04:16 PM
Default Re: Wastegate Problem (B18EG6)
It was pinched together by the top of the wastegate... The pictures are after I tried to fix it a little... It used to be pinched like perfectly flat.
Old Jan 31, 2004 | 09:53 AM
bump for some help
Old Jan 31, 2004 | 10:32 AM
Blaze45's Avatar
Brrraaaap!
Bump, someones gotta know whats going on w/ this guys wastegate.
Blaze
Old Jan 31, 2004 | 10:36 AM
Frozen E's Avatar
H-T White Ops
I'm new to this whole boost thing, but it looks like the rubber diaphram went bad. You say it was pinched. It's only rubber and the wastegate gets warm, so it probably got a little deformed. Just enough to where it won't make a good seal anymore. See if you can buy just a replacement diaphram. Should be able to and have it be as good as new.
Again, I'm brand spankin' new at this.
Old Feb 4, 2004 | 12:57 PM
Default Re: (IslandSi)
Ordered a new diaphram... We'll see if thats the problem.
one slooow dc4
Sep 23, 2009 10:49 AM
arsenal1499
Sep 2, 2008 08:23 AM
Black DC2
Feb 9, 2005 08:20 PM
smnowell
Feb 5, 2005 03:26 PM
