Blowing wastegate gaskets
Old Aug 25, 2005 | 07:54 AM
Akalima's Avatar
Default Blowing wastegate gaskets
Okay i have a 38mm Tial wastegate it came with two gaskets. The bolts for the flange between the manifold and wastegate loosend off and toasted the gasket. The down pipe was still okay. My garage then ordered my gasket header gasket and made 2 new gaskets, they are almost like heavy duty paper and it ****** blew the bolts were tight. I want to put the origional tial gasket in there and make sure the bolts are tight is theis a commen problem or is there a solution like using header cement or what?
Old Aug 25, 2005 | 08:03 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Blowing wastegate gaskets (Akalima)
you dont need a gasket. the fire ring should seat just fine without one. tial gaskets suck to begin with
Old Aug 25, 2005 | 08:14 AM
Finland's Avatar
I agree, the Tial gaskets are not very good. also you may want to put a straight-edge on your flanges to make sure they aren't warped, if that's the case, no matter how good the gasket is, it won't seal.
Old Aug 25, 2005 | 08:19 AM
bubbahatch92's Avatar
worst comes to worst you could always use some red high temp rtv silicone and see if that will hold.
Darkness
Old Aug 25, 2005 | 08:32 AM
Quad-Damag's Avatar
Default Re: Blowing wastegate gaskets (bubbahatch92)
the tial gaskets are crap
get a turbonetics gasket it's much thicker and will last alot longer
Old Aug 25, 2005 | 08:37 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Blowing wastegate gaskets (Quad-Damage)
i just used the firering and it works just fine.
Old Aug 25, 2005 | 09:18 AM
Akalima's Avatar
Default Re: Blowing wastegate gaskets (Hella_JDM)
so u guys have no gasket just metal on metal and it holds that impressive thats for the advice you guys have been a huge help
Old Aug 25, 2005 | 10:08 AM
bnut510's Avatar
atpturbo has some good gaskets for the wastegate. i was running without one for a lil bit but the screws would shake loose after a while and eventually seperate from all the vibration i would imagine, since i was running it straight out the down pipe. anyways check out their site, the gaskets they sell are really good quality.
Old Aug 25, 2005 | 11:05 AM
Sketch_hs's Avatar
just use the ring!
works great
Old Aug 25, 2005 | 11:07 AM
AspectIndustries's Avatar
Default Re: (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">just use the ring!
works great</TD></TR></TABLE>
GWInquisitor14
Sep 25, 2005 11:30 AM
95GSRTT
Jun 10, 2004 05:16 PM
mskibbz-T
Apr 24, 2004 11:36 PM
Etylorcen
Feb 24, 2002 01:39 PM
