which wastegate do i use?
Old Sep 16, 2007 | 10:16 AM
VTEC_PRODUCTION's Avatar
Default which wastegate do i use?
the 38mm or 44mm? i have the blowzilla t3 on a build b18b block, will run high boost...
thanks guys...
Old Sep 16, 2007 | 10:45 AM
Default Re: which wastegate do i use? (VTEC_PRODUCTION)
cool man
Old Sep 16, 2007 | 10:54 AM
RCautoworks's Avatar
38mm should be fine if your running high boost, depending on how much power you're making though. The bigger wastegates are good to control low boost.
Modified by RCautoworks at 2:20 PM 9/16/2007
Old Sep 16, 2007 | 11:18 AM
Default Re: which wastegate do i use? (RCautoworks)
ok thank you very much...
Old Sep 16, 2007 | 11:22 AM
RC000E's Avatar
Try out the Synapse man....
Old Sep 16, 2007 | 11:31 AM
93hatched_projekt's Avatar
Default Re: which wastegate do i use? (RC000E)
Dont waste your time or money . Go with a 44mm or 50mm off the bat. Dont get me wrong , you can make a 38mm work but wg placement becomes more important . I'm running a 38mm right now up to around 23 psi but a bigger wg would work better for my application.
Old Sep 16, 2007 | 11:59 AM
50 mm???<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Try out the Synapse man....</TD></TR></TABLE>
Old Sep 16, 2007 | 05:55 PM
RC000E's Avatar
You should add "or blown out" to your sig line VTEC_PRODUCTION.....hahahaa
hot and stick and blown out....LOL....
Ahhh I'm tired....
Old Sep 16, 2007 | 06:02 PM
Schister66's Avatar
Man U FTW
i'd get a Tial 44mm just to be on the safe side....
Old Oct 7, 2007 | 04:07 PM
SiR Koopa's Avatar
Default Re: (Schister66)
so what is there to know about knowing which size to get for ur build? cuz im in the look out for buying a wastegate for my kit aswell and i can easily just listen to some one (not saying ur wrong) and buy it but id like to know how u came up with that decision... cuz i plan on looking at around 500 hp... some one said smaller wg for high psi? and bigger wg for low psi?
Old Oct 7, 2007 | 05:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (SiR Koopa)
depends on placement and what the manifold os flanged for.
f.w.i.w. nasteboyii tamed my t3t67ho to 10 psi with a 38mm.
my 44mm works well on my setup.
Old Oct 7, 2007 | 05:16 PM
Topdawgg's Avatar
tial 44mm or synapse 50mm..
Old Oct 7, 2007 | 09:58 PM
SiR Koopa's Avatar
Default Re: (Topdawgg)
what do u mean by placement ( sorry new to turbo) and as far as the flange im having the manifold made to my specs so either or it can be fitted for
Old Oct 8, 2007 | 04:12 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Koopa &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean by placement ( sorry new to turbo) and as far as the flange im having the manifold made to my specs so either or it can be fitted for</TD></TR></TABLE>
where the gate is. like is it pulling from all 4 ports, or one like a grag manifold?
Old Oct 8, 2007 | 04:07 PM
SiR Koopa's Avatar
Default Re: (boostedcivicsir)
ahh ok thats what i thought u ment just wanted to make sure
Old Oct 8, 2007 | 06:54 PM
s52b32's Avatar
if it hasnt be said yet ill break it down for you or maybe others. typically if you have a big turbo that can flow lots of air and you are running little boost you would want a bigger wastegate. if in the above mentioned case you went with to small a wastegate you couldnt regulate boost fast enough and youd get boost creep.
Old Oct 8, 2007 | 07:49 PM
brute's Avatar
Default Re: (s52b32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I have found a common misconception among sizing of wastgate for horsepower goals. Here are my thoughts:
The wastegate sizing is largely dependent upon the boost pressure being regulated, and the exhaust energy from the engine the wastegate is being used upon. The way in which a wastegate works is to regulate the amount of exhaust energy, or exhaust gas that travels into the turbine housing of the turbocharger. At lower boost levels, more exhaust gas is being bypassed to sustain the lower pressure. The reason is that to keep the exhaust flow that goes into the turbine housing to a lower pressure, more exhaust energy is to be bleed from the exhaust manifold. So at lower boost pressures, the size of the wastegate becomes critical in order to regulate the amount of exhaust energy that travels into the turbine housing. The physical size of the wastegate should be larger, or have a larger diaphram and valve to bleed off the most amount of pressure. As higher and higher boost pressure are enabled, less exhaust energy is to be bleed from the system. The wastegate valve is opened less and less, so the physical size of the wastegate (i.e wastegate valve size; ex. 35mm is 35mm valve, etc) being used is to be smaller and smaller.
Besides the amount of boost pressure being regulated, the compression and displacement play a huge role in the amount of exhaust energy available in the exhaust manifold. The greater the displacement and compression, the larger the wastegate size should be used. Its a very simple relationship between boost pressure, displacement and compression ratio of the engine the wastegate is being used upon. A side note, the larger wastegate typically holds boost pressure more stable than the smaller wastegate size. Most, if not all cases of unstable boost is created from poor wastegate placement. If wastegate placement is pre-dictated from the manufactuer, and unstable boost is a problem a larger wastegate should be employed. The Tial 35/38mm wastegate is sufficient for 500-600whp level, which is contradictory to what most turbo Honda's use at higher boost levels.</TD></TR></TABLE>
davidluko
Apr 10, 2007 01:17 AM
gsrt
Oct 16, 2006 11:24 PM
88crxhfb16
Aug 2, 2005 08:54 PM
W O T
Jan 23, 2005 09:08 PM
BoostedsiR
Mar 17, 2004 10:59 AM
