wastegate
Old Jul 19, 2001 | 12:12 AM
CrAZyRaCeR's Avatar
New User
Default wastegate
sup fellaz,this is my first post....anywayz, straight to the topic.....i want to get a drag 3 turbo kit for my gsr but i'm unfamiliar with "the dark side"...what else is involve in a turbo kit besides the kit itself??? i heard that the delta wastegate leaks, has anyone experience that??? will a tial wastegate be better or just a waste of money??? since i only wanna run stock boost for now, do i have to upgrade my ignitions system??? if so, what is involve??? oh yeah, is the stock boost for the Drag 3 kit 7.5 psi??? sorry for the long post...i cant think of any now, but i'm sure i'll be coming back for more.... any help from you turbo guys will be much appreciated....
thanx,
jim
Old Jul 19, 2001 | 12:29 AM
ssblue's Avatar
Default Re: wastegate (CrAZyRaCeR)
i was previously a skeptic on the benefits of the tial as opposed to the deltagate before i felt the difference...the deltagate kinda bleeds the boost but the tial doesn't open until you get to the desired boost level. imo, definitely upgrade to the tial before you purchase the kit, that way you'll save yourself some money. also, an ignition is not necessary (although i'm sure it has it's benefits) but colder sparkplugs would be a good idea.
Old Jul 19, 2001 | 12:51 AM
CrAZyRaCeR's Avatar
New User
Default Re: wastegate (ssblue)
thanx for the input but what does "bleeds the boost" mean??? sorry if it sound trivial, i'm new @ turbos
Old Jul 19, 2001 | 06:25 AM
b18bturbo's Avatar
the deltagate is not a bad wastegate when you running minmial boost say 4-6psi but after you start messing wiht things and cranking it up to like 9-10psi it starts to fail. The better bet is the 35mm tial wastegate. What bleeding the boost means it will not hold the boost where it needs to be based on the spring inside the wastegate. It will bleed to much or not enough. The tial on the other hand works just right.
Old Jul 19, 2001 | 08:38 AM
CrAZyRaCeR's Avatar
New User
Default Re: wastegate (b18bturbo)
hey b18turbo and ssblue, can you guys tell me what kind of a turbo set up u guys have right now??? ssblue, i see in ur signature that you have a drag 3 turbo, how much boost are u running and what other upgrades u have for your turbo (ex: fuel, ignition, retard timing, and etc.) also, i saw on optauto.com that a drag 3 turbo kit will run me around $2950, you guys think i can get a better deal???
thanx fellaz, your inputs were very helpful and informative...
Old Jul 19, 2001 | 08:59 AM
redline's Avatar
Talk to ben from importparts.com on the price for Drag kits
k
Old Jul 19, 2001 | 09:27 AM
b18bturbo's Avatar
my car is fully race car so i really cant compare to any street setups. My old hb although had revhard stage II with tial upgrade. it boosted approx 12psi and ran 12.8. I like the revhard kits over the drag. Either one is good though for the price. Usually around 3195
Old Jul 19, 2001 | 10:07 AM
Doodoo's Avatar
Get the Tial dude. My friend cranked up his boosted LS to 15psi w/ a deltagate, he ended up spiking at 18 then 20psi!! His Total Seal rings fell apart, thats all. Get the Tial, it looks cool too.
Old Jul 19, 2001 | 12:10 PM
CrAZyRaCeR's Avatar
New User
Default Re: wastegate (Doodoo)
does anybody have picture of delta wastegate and a picture of tial wastegate??
Old Jul 19, 2001 | 05:01 PM
Tr0LL's Avatar
will the deltagate have boost creep even at low boost?? like 5-6 psi??
Old Jul 19, 2001 | 06:13 PM
Flamenco-T's Avatar
Default Re: wastegate (Tr0LL)
Speaking of all this, I have a Deltagate wastegate 9 psi spring for sale...went to Tial instead....$ 110 shipped
arsumirat@hotmail.com
Old Jul 20, 2001 | 11:32 AM
ssblue's Avatar
i have a drag gen 3 with the tial upgrade, timing retarded 2 degrees and ngk copper plugs running .55bar or ~8 psi controlled by an avc-r. i got the kit and tial from ben@importparts.com because he had the best prices i could find anywhere.
Old Jul 21, 2001 | 09:54 AM
DirtyLude's Avatar
The TIAL 35mm. It's a work of art.
2muchPSI
Oct 19, 2003 07:07 PM
rbf351
Dec 17, 2002 06:10 AM
XforgivenX
Sep 25, 2001 05:26 PM
BluLuder
Sep 13, 2001 04:38 AM
