Explanation of wastegate sizes?
Old Oct 19, 2003 | 03:34 PM
2muchPSI's Avatar
Default Explanation of wastegate sizes?
I am new to the whole forced induction thing, and have a question for you veteran turbo guys. I searched and couldnt find any helpful information. I have a drag 3 kit on my civic, and the shitty deltagate took a dump on me. I want to replace it with a Tial wastegate. Can someone please explain to me the difference between say a 35 mm wastegate, and a 40 mm wastegate. I understand what size springs to use for desired boost levels, just not the millimeter size. Thanks
Old Oct 19, 2003 | 03:41 PM
twkdCD595's Avatar
Default Re: Explanation of wastegate sizes? (2muchPSI)
the mm number tial uses I believe is the measure of the valve inside the wastegate that releases the exess boost pressure.
a huge wastegate is not always ness. try the 35-38mm wastegates.
http://www.tialsport.com/technical.htm
Old Oct 19, 2003 | 04:39 PM
2muchPSI's Avatar
Default Re: Explanation of wastegate sizes? (twkdCD595)
thanks, looks like the38mm wastegate is what ill go with. If I want to run about 7 lbs of boost under normal driving conditions, should I go with the .5bar spring, or go lower? I have a greddy profec b boost controller to find tune the amount of boost. Thanks
Old Oct 19, 2003 | 05:19 PM
Ben Huynh's Avatar
0.5Bar will put you at about 7.5psi and that will be your base (minimum) boost level.
Old Oct 19, 2003 | 05:21 PM
falcongsr's Avatar
What is this crap?
Default Re: Explanation of wastegate sizes? (ben@importparts.com)
7.25psi punk
Old Oct 19, 2003 | 05:26 PM
Ben Huynh's Avatar
Default Re: Explanation of wastegate sizes? (falconGSR)
I was rounding up PUNK. lol
Old Oct 19, 2003 | 05:31 PM
twkdCD595's Avatar
damn ben your slipping... hehehe
Old Oct 19, 2003 | 05:46 PM
2muchPSI's Avatar
So should I maybe go a step lower, and then just turn it up with my boost controller to 7 psi?
Old Oct 19, 2003 | 07:07 PM
Ben Huynh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">damn ben your slipping... hehehe </TD></TR></TABLE>
Yes I think old age is getting to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">So should I maybe go a step lower, and then just turn it up with my boost controller to 7 psi?
Yea that would be your best choice.
alperx
Jan 24, 2012 12:22 PM
60-1
Mar 18, 2004 11:30 PM
EH2LS
Sep 27, 2003 01:02 PM
austrian type-R
Feb 12, 2002 07:45 AM
