Want to put turbo kit together, need to know what i need!
I was looking to boost my car and decided to put one together myself. Besides the turbine, i dont know what else i would need. If you guys could help, or have a old kit or even hook ups it would be greatly appreciated. Thanks
Re: Want to put turbo kit together, need to know what i need! (p1ccoloz)
Re: Want to put turbo kit together, need to know what i need! (tegasaurus)
Use the search function and you will learn tons.
-Turbocharger
-Turbo manifold
-Down pipe
-Wastegate
-Intercooler
-Blow off valve
-Filter
-Charge pipes
-Oil feed and return lines
-Silicon couplers for charge pipes
-Colder range spark plugs
-Vacuum lines
-Miscellaneous gauges (boost, oil pressure, fuel pressure, EGT)
-Fuel Management --variety of ways you can go with this based on needs…
-Turbocharger
-Turbo manifold
-Down pipe
-Wastegate
-Intercooler
-Blow off valve
-Filter
-Charge pipes
-Vacuum lines
trust me, with this, your motor will last a lot longer than some of us who just slap it on, and expect to have a tuesday motor...not too mention, you can learn a lot by reading and observing than asking questions
stan
stevn
01-15-2009 02:31 PM
