walbro fuel pumps...please read...
Old Jun 28, 2003 | 08:26 PM
99lspwr's Avatar
Default walbro fuel pumps...please read...
Whats up guys... Tonight I noticed something a little scary with my car. I was doing a full throttle blast when I noticed that around 5k in fourth gear my wideband a/f gauge started creeping up on me fast from 12.0 to 13.0 and then a little higher Also with this my car started to fall on its face very bad, so I looked at my gas gauge and the needle was just about on the red.. Just for the hell of it I did another quick blast and the same thing happened.. I thought I remembered hearing something about the walbro fuel pumps not liking a low tank, so I filled my car up w/3 gallons of gas, did another blast and everything felt back to normal. Has anyone ever expirenced a problem like this??? BTW, my fuel setup is a 255 lph in tank pump, fmu w/6-1 disc and 310cc injectors.. Any help is greatly appriciated...
Old Jun 28, 2003 | 08:29 PM
MiraiZ's Avatar
Default Re: walbro fuel pumps...please read... (99lspwr)
how low was the tank?
Old Jun 28, 2003 | 08:43 PM
99lspwr's Avatar
Default Re: walbro fuel pumps...please read... (MiraiZ)
The needle was just about on the red...
Old Jun 28, 2003 | 08:45 PM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">The needle was just about on the red...</TD></TR></TABLE>
I think that's your problem
Old Jun 28, 2003 | 08:58 PM
AlphaKennyWun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">
I think that's your problem</TD></TR></TABLE>
Old Jun 28, 2003 | 09:29 PM
sweet's Avatar
Default Re: walbro fuel pumps...please read... (S03Burner)
i don't know cause i normally will not let the needle go down that far, nor will i hit WOT or higher rpm when the gas tank is low. i always try to keep at least an 1/8 of a tank if not a 1/4 tank of gas. there is a point where even with a stock fuel pump i would feel a difference when the tank got down to about 1/4 tank or less, less power possibly due to less fuel being pumped. since last year i've been using a Walbro 255 intake pump, but no problems like what you mentioned that i recall.
Old Jun 29, 2003 | 05:27 AM
toxicshit's Avatar
hmm with the full tank no problems ?
Old Jun 29, 2003 | 07:40 AM
99lspwr's Avatar
Default Re: (toxicshit)
I am going to do a couple more full throttle passes today to see if the problem returns... I think the gas was just too low, but I wanted to see if anyone could confirm this..
Old Jun 29, 2003 | 08:20 AM
E Swift's Avatar
Default Re: (99lspwr)
Yeah you don't want to let the fuel get down that low. Not good for the fuel pump.
Old Jun 29, 2003 | 10:52 AM
94dxt's Avatar
Default Re: (E Swift)
That's not a Walbro problem, that's the way any fuel pump is. In a Honda tank any way. It doesn't need to be a full tank just don't let it get lower than 2 gal or so.
Old Jun 29, 2003 | 07:14 PM
99lspwr's Avatar
Default Re: (94dxt)
So basically that could of been my problem.... I ran it a few times today and everything seemed normal.. A/F ratio was where it usually is...
Old Jun 29, 2003 | 07:58 PM
boostedcivicsir's Avatar
Mr. Badwrench
that was a big problem with the typhoons and syclones.
less than 1/4 tank the baffles couldnt handle a parking brake holeshot.
usually melted stuff.
91cb7h23
Feb 10, 2013 04:13 PM
drwoody
May 28, 2010 05:52 PM
93integraB
Feb 10, 2006 07:36 PM
JLHDOHC
Feb 28, 2005 03:05 PM
Lowez
Jan 20, 2002 04:48 PM
