has anyone had this problem?
Old Feb 8, 2013 | 07:40 AM
91cb7h23's Avatar
Default has anyone had this problem?
OK so my 91 cb seems like it has a fuel delivery issue going around right hand on or off ramps the gas has drops dramatically. When coming to an abrupt stop it drops. Is it something in the tank or a regulator issue. Please help if you can
Old Feb 8, 2013 | 07:44 AM
NZXTInerTia's Avatar
Default Re: has anyone had this problem?
Sometimes when I'm low on gas I have troubles starting my car, just due to the fact that the pickup isn't reaching the fuel. Fuel tanks suck on our Accords because you actually have to remove them to get to the sending unit. Do you have a full tank of gas? lol
Old Feb 8, 2013 | 09:17 PM
91cb7h23's Avatar
It will have like a half tank and then when I go around a on ramp where the gas gets sloshed to 1 side I lose almost 1/4 a tank
Old Feb 9, 2013 | 12:40 AM
giovannie23's Avatar
mine does the same thing ...even if i stop hard it drops
Old Feb 9, 2013 | 12:57 AM
dnguyen2010's Avatar
replace your fuel pump
Old Feb 9, 2013 | 01:05 AM
Swap'DShuttle's Avatar
My EE Wagon has fuel cut issues on hard left turns when Im under 1/3 tank. No baffles ftl. Clean your tank, fuel lines and fuel pump sock just for *****, and keep gas in her.
Old Feb 10, 2013 | 05:08 AM
poorman212's Avatar
OP- is this just an issue with the gauge or is there an issue with the car actually running?
Also note that the fuel pump for the engine and the sending unit for the gauge are two different things.
Old Feb 10, 2013 | 04:13 PM
holmesnmanny's Avatar
The best thing to do is to actually test your fuel pressure. You can get a fuel pressure kit from Harbor Freight. Hook it up and have the gauge sticking out of the hood while driving and see if pressure goes down. If so then you have a fuel filter, fuel pump, or fuel blockage(possibly fuel strainer in tank) issue. If your problem is not performance but just the level is off, then the problem is probably related to the sending unit. It's not the easiest job to drop the tank.
Hondaisok
Sep 27, 2010 09:30 AM
EJ1B18c
28
Aug 24, 2010 08:19 PM
drwoody
May 28, 2010 05:52 PM
red civic standard
May 17, 2004 10:54 AM
Propulsion
Jul 8, 2002 11:15 AM
