Stalling on low fuel!!!!
Old Jan 20, 2002 | 01:15 PM
Lowez's Avatar
Default Stalling on low fuel!!!!
Whenever the fuel gauge is low, almost but not quite in the red part my 92 civic stalls, starts up again goes for a while then stalls agian. Eventually it doesn't start at all after a few stalls. When I fill up everything is good again and no problems till I reach the low mark again. What gives?? Has anyone had this problem before? This started after I got hit from side, on the drivers side, right by the fuel latch!!Thanks for any imput!!!
Old Jan 20, 2002 | 01:17 PM
Jared's Avatar
Default Re: Stalling on low fuel!!!! (Lowez)
sounds like your gauge is not really reading correctly compared to what your pickup is actually able to get, most likely when you were hit it may have dented the gas tank, thereby giving you less volume in the tank and you're running out of gas earlier.
Old Jan 20, 2002 | 01:29 PM
fastestdriver's Avatar
you better pull the tank and see what gives. fuel tank is probaly tweaked. Maybe fuel pickup is bent?
Old Jan 20, 2002 | 04:15 PM
93LSivic's Avatar
My input is this: Simply put. Keep gas in the tank. Its not good to run the tank low cause dirt gets in the filter and clogs it. Keep atleast 1/4, dont go any less.
Old Jan 20, 2002 | 04:48 PM
tinkerbell's Avatar
Default Re: Stalling on low fuel!!!! (93LSivic)
input wholeheartedly seconded,
also cause it helps the intank pump run a bit cooler...
t..
89ED
Jul 5, 2013 08:33 PM
91cb7h23
Feb 10, 2013 04:13 PM
vrrodri
Jun 29, 2011 05:32 AM
drwoody
May 28, 2010 05:52 PM
crazycaucazian86
Apr 19, 2006 10:12 AM
