walbro fuel pump noise?
Old Feb 19, 2002 | 04:46 AM
td04civic's Avatar
Default walbro fuel pump noise?
i just installed a walbro 255lph intank fuel pump. Is it supposed to make a noise?
just wondering. Thanks
Old Feb 19, 2002 | 05:12 AM
TurboSedan's Avatar
New User
Default Re: walbro fuel pump noise? (td04civic)
Yes, at least mine does for sure. It is a mild humming sound that I can hear at idle because I still have a stock exhaust. When the 3" Thermal goes in, I imagine I will barely hear it if at all.
Old Feb 19, 2002 | 06:41 AM
VTC_CiViC's Avatar
Yea it's pretty noisy. Like the humming you hear inside an airplane.
Old Feb 19, 2002 | 06:54 AM
Pritos's Avatar
New User
Default u'll hear it
when u are at a red with your turn signal on. sounds like WEEEEEWERRRRRWEEEEEWERRRRRWEEEEWERRRRR
Old Feb 19, 2002 | 07:45 AM
Anubyss's Avatar
Has anyone tried dynamatting the fuel tank to reduce the noise? I think that will help. I've dynamatted the trunk to reduce the noise coming from the exhaust and it helped a bit. I'll be doing the tank as well when my Walbro pump arrives.
Old Feb 19, 2002 | 09:18 AM
4dGSR at work's Avatar
Default Re: u'll hear it (Pritos)
i love that... good for a chuckle everytime..
(turning signal)
holley pump in my case....same thing
Old Feb 19, 2002 | 09:20 AM
TurboSedan's Avatar
New User
Default Re: (Anubyss)
Dynamat, good idea. I have some of that left over somewhere, hmmmmmm.
Old Feb 19, 2002 | 09:44 AM
FuzzyGreen's Avatar
Did you guys switch your fuel pump fuse to a 15amp after installing the fuel pump?
Old Feb 19, 2002 | 09:46 AM
VTC_CiViC's Avatar
LOL yep, I love that sound
Old Feb 19, 2002 | 10:11 AM
ZygSpeed's Avatar
Default Re: u'll hear it (VTC_CiViC)
I was getting a bit paranoid about it a little while ago.
Glad it's "normal".
Old Feb 19, 2002 | 10:17 AM
TurboSedan's Avatar
New User
Default Re: walbro fuel pump noise? (FuzzyGreenCarpets)
Why would we want to switch it to 15amp? Necessary to not have the OEM fuse blow under high load?
Old Feb 19, 2002 | 10:21 AM
FuzzyGreen's Avatar
Default Re: walbro fuel pump noise? (97CivicFerio)
That's whay I'm asking, the instructions that came with my turbo kit says to switch the fuse, but I can't figure out if it does anything.
[Modified by FuzzyGreenCarpets, 7:21 PM 2/19/2002]
Old Feb 19, 2002 | 12:02 PM
dbman96's Avatar
New User
You're supposed to hook it up to the fuel pump relay, not your fast-blinky turn signal box!!!
Old Feb 19, 2002 | 12:27 PM
Pritos's Avatar
New User
Default dynamat
i dont think it'll work. the gas will dissolve the adhesive. Unless you zip tie or hose clamp it on.
Old Feb 19, 2002 | 12:53 PM
Anubyss's Avatar
I didn't say to dynamat the pump, I said the tank. That would be on the outside of the fuel tank.
Old Feb 19, 2002 | 12:56 PM
TurboSedan's Avatar
New User
Yeah, I thought you meant all outside of the fuel tank too. No way would I condone someone putting that stuff inside the tank! DOH!
Old Feb 19, 2002 | 03:15 PM
dbman96's Avatar
New User
Default Re: (97CivicFerio)
Um... fill the gas tank with spray foam - that will quiet it down!
Old Feb 19, 2002 | 03:20 PM
TurboSedan's Avatar
New User
Default Re: (dbman96)
THE MPG WILL JUST ROXORS THEN!!!!!
Old Feb 19, 2002 | 03:21 PM
LsTurbo91's Avatar
mine is pretty quiet, compared to my inline pump before
Old Feb 19, 2002 | 04:47 PM
Dee's Avatar
Dee
Default Re: (LsTurbo91)
just another beautiful turbo noise for me...
rattling metal clutch
whining pump
screaming open w/g
wooshing bov
I'm in wuv !!
Old Feb 19, 2002 | 06:00 PM
GruvyTune's Avatar
New User
i hear my MSD ignition more than i hear the walbro.
superbangkok
Oct 6, 2006 08:46 AM
Fat Chick Magnet
Aug 29, 2006 05:55 AM
Eluzion
Apr 11, 2004 09:51 PM
sporkcrx
Feb 5, 2003 08:48 AM
