Walbro 255
Old May 26, 2009 | 09:38 AM
HarfordCTR's Avatar
Default Walbro 255
How can you tell if it is a Walbro 255 from looking at it? TIA
Old May 26, 2009 | 10:04 AM
damndan23's Avatar
Default Re: Walbro 255
walbro is stamped on the metal part i believe!
Old May 26, 2009 | 10:53 AM
dpetro1's Avatar
part# is stamped on the side
255 = gss315 or gss317
255hp = gss340, gss341, gss342
Old May 26, 2009 | 11:32 AM
HarfordCTR's Avatar
Whats the difference in the HP and the regular?
Old May 26, 2009 | 10:03 PM
project dc2's Avatar
HP = high pressure
better for turbo setups because it requires the setup to run more fuel pressure
Old May 27, 2009 | 04:26 AM
dpetro1's Avatar
Originally Posted by project dc2
HP = high pressure
yup, essentially the HP can continue flowing at higher pressures. the regular starts dropping off quickly after 60psi
Old May 27, 2009 | 07:05 AM
HarfordCTR's Avatar
In the 300-350 whp range would the non HP be ok?
Old May 27, 2009 | 07:25 AM
dpetro1's Avatar
simple answer yes. technical answer...depends on the fuel pressure. basically as long as you arent running 30+ psi or using an fmu or something to increase the pressure drastically then the regular 255 is fine.
stock fuel pressure is 38psi + 12psi of boost = 50psi total fuel pressure. Both pumps are able to flow about 50 gallons/hour or 3150cc/min
Old May 27, 2009 | 07:41 AM
HarfordCTR's Avatar
won't be running high boost, and no FMU. Hondata S300, RC 750's
Old May 27, 2009 | 09:45 AM
dpetro1's Avatar
then either will work, the HP is only $10 more so might as well pick one up.
Old May 27, 2009 | 11:34 AM
HarfordCTR's Avatar
I already have it
Old May 27, 2009 | 11:50 AM
Ls_dx's Avatar
this is some good info
Esprit09
Nov 8, 2009 11:12 AM
danno33
Dec 27, 2006 02:16 PM
Jdmb16sir2
Apr 23, 2006 08:35 AM
clemsonteg
Jan 18, 2006 08:31 PM
djnikko
Dec 7, 2003 10:42 AM
