Problem with VAFC
Old Jan 19, 2002 | 11:47 PM
HX_Guy's Avatar
Default Problem with VAFC
Has anyone experiances this? Im not sure if its the VAF or if there is something else going on.
Whatever I set the VAFC to kick VTEC on, it delays it ~200 RPMs. Like now, my VAFC VTEC is set at 4700, yet it kicks in at 4900. Is there something wrong with the VAFC? The motor? (already tired a second solenoid and same thing)
Old Jan 19, 2002 | 11:49 PM
sgT's Avatar
sgT
Default Re: Problem with VAFC (HX_Guy)
what are you getting the rpm reading from?
Old Jan 20, 2002 | 12:02 AM
HX_Guy's Avatar
Default Re: Problem with VAFC (sgT)
The dyno and from looking at the VAFC RPM readout
Old Jan 20, 2002 | 09:20 AM
HX_Guy's Avatar
Old Jan 20, 2002 | 09:23 AM
sgT's Avatar
sgT
yeah, ive seen that with VAFC before.
dono why though.
Old Jan 20, 2002 | 09:27 AM
HX_Guy's Avatar
Im thinking about taking it back and getting another one..hmm.
Old Jan 20, 2002 | 09:29 AM
sgT's Avatar
sgT
lol
it will probably do the same thing.
be happy, the blue screen is still better than the field right??
Old Jan 20, 2002 | 09:31 AM
HX_Guy's Avatar
Hahaha, hey I like the Blue screen! And anyway..how many adjustment points does the Field's have? The VAFC has 16
Ill try out a friend's VAFC first before I exchange mine.
Old Jan 20, 2002 | 09:33 AM
Black R's Avatar
25 Year Member
.....well you know the stock tach is off by ~200 rpms or so. At least mine is.
If it's off by the rpm reading on the vafc in monitor mode, then check and see what your lvt and hvt correction points are. Probably, you have vtec set to go on at a certain rpm, but your lvt and hvt correction points don't share that same rpm..... post up your correction points and also your vtec l--->h and h--->l. I think that's the problem.
Never had any of the aforementioned problems with mine.
*knocks on wood*
Old Jan 20, 2002 | 09:50 AM
sgT's Avatar
sgT
you cant really say that the afc has 16, because all 16 arent on one page.
and val, what are your low throttle settings?
or does a vafc do highcam/lowcam instead of highthrottle/lowthrottle
Old Jan 20, 2002 | 11:24 AM
EGtoR's Avatar
Default Re: Problem with VAFC (Black R)
so the lvt and hvt correction point have to share the same VTEC switch over point as it set on the VAFC?
Old Jan 20, 2002 | 01:02 PM
DC2R714's Avatar
Default Re: Problem with VAFC (EGtoR)
I have that as well. I thought it might be the vtec correction setting where if your Vtec is lower than stock you adjust for it. I have mine set at 4700 and doesnt go till 4900, and my vtec correction is set at +2, no clue if that effects the vtec xover.
Old Jan 20, 2002 | 03:28 PM
tooqwik1's Avatar
check ur conection where u hooked up your wires to the harness
did u crimp em on or solder? i had that problem but i soldered it and now it wrks perfect
Old Jan 20, 2002 | 03:46 PM
Kilika2k's Avatar
New User
Default Re: Problem with VAFC (tooqwik1)
I don't think its the VAFC. Typically, Honda Tachs tend to be very optimistic about RPMs so it could really be switching at 4700 but the tach just says 4900. I guess when you have a high revving engine, the chances of error are a bit higher.
Old Jan 20, 2002 | 05:09 PM
sgT's Avatar
sgT
Default Re: Problem with VAFC (Kilika2k)
My field vtec controller is dead on
not with the tach mind you, but with itself and the actual rpm reading.
Old Jan 20, 2002 | 05:40 PM
HX_Guy's Avatar
The connections re soldered
SGT: The VAFC actually has 32 points of adjustment.
8 for low throtttle/non vtec
8 for low throttle/vtec
8 for high throttle/non vtec
8 for high throttle/vtec
All my low throttle points are at 0
Daily Interlude
Nov 5, 2004 06:11 AM
ShakesTheKlown
May 10, 2004 03:16 PM
egturbo
Mar 21, 2004 01:25 PM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
KC GSR
Aug 31, 2002 10:51 AM
