Vtec timing under boost
Old Jul 1, 2005 | 10:26 AM
Qveon's Avatar
Default Vtec timing under boost
I have read somewhere that some people have less timing pulled under boost when in vtec then when not in vtec under boost. Is this a a good tuning tactic? If so can you elaborate why its good tactic and could you share some examples?
Old Jul 1, 2005 | 10:58 AM
urbansi's Avatar
Default Re: Vtec timing under boost (Qveon)
bumo for also wanting to know
Old Jul 1, 2005 | 12:44 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon &raquo;</TD></TR><TR><TD CLASS="quote">I have read somewhere that some people have less timing pulled under boost when in vtec then when not in vtec under boost. Is this a a good tuning tactic? If so can you elaborate why its good tactic and could you share some examples?</TD></TR></TABLE>
I keep it the same when im tuning a car.. Generally I found with boosted car that your vtec point is higher.. The only way to tell where the perfect place to set it is on a dyno where you can overlay the high-cam and low-cam torque plots..
civicboy1128
Aug 5, 2008 12:39 PM
PKSPX
Mar 5, 2004 02:59 PM
greengangsta
Jan 2, 2002 12:29 PM
