vtec problem with my boosted b16 eg
in third gear vtec engages and at 6000 rpm it turns off after that vtec doesnt work any more and my car runs sluggish and idles at 1100 rpms of 800 rpms have to turn car off and then on to make car run rig,ht and vtec to work. help throwing 1,3,19(using auto p28) running off vortech fmu till i get it tuned
this only happens when i get to third 4th, and 5th gears 1st and 2nd is fine pulls good and runs great
can somebody help me or tell me what you think it is
going to get it tuned kind of low on money only way of transportation so I have to live with it can someone help me?
wtf ? you're running untuned with a fmu AND a completly incorrect ecu and you're complaining that vtec isnt hitting.. i would take your car to someone who actually knows what they're doing before ripping on it any more
since vtec isnt engaging correctly you may also have an oil pressure problem. vtec needs oil pressure to work...if your oil pressure is dropping off the vtec will turn off.....if you rev a vtec motor with no vtec you risk doing damage to the head.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmegsix »</TD></TR><TR><TD CLASS="quote">in third gear vtec engages and at 6000 rpm it turns off after that vtec doesnt work any more and my car runs sluggish and idles at 1100 rpms of 800 rpms have to turn car off and then on to make car run rig,ht and vtec to work. help throwing 1,3,19(using auto p28) running off vortech fmu till i get it tuned
can somebody help me or tell me what you think it is</TD></TR></TABLE>
Pretty much Code 3 is why your car is running like ***.
Get the thing tuned already.
Are you running a missing link or a check valve?
car ran fine with the ecu before I put the turbo in vtec engaged fine no missing link on i didn't bother cause I have a 3 bar map sensor but can run it till I get it tuned
how do you make a check valve?
Modified by jaydmegsix at 12:39 PM 2/16/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmegsix »</TD></TR><TR><TD CLASS="quote">car ran fine with the ecu before I ut the turbo in vtec engaged fine no missing link on it didn't bother cause I have a 3 bar map sensor but can run it till I get it tuned
how do you make a check valve?</TD></TR></TABLE>
Hold on. What are you talking about? You are running a 3bar map sensor on the stock ecu.. I doubt that. Unless you mixed that up and said you weren't going to run it untill you get tuned.
Basically you are screwed without a missing link or any kind of engine management. So stop beating on the car, just drive it. Don't boost it at all is my recommendation untill you get someone to tune it for you.
Who is Mr Robot?
you are a tool
you are a tool
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">I give up ...if you cant type or speak clearly theres no use trying to help you ... pay someone to fix it </TD></TR></TABLE>
