VTEC Pressure Problem
Old May 11, 2003 | 11:11 AM
PWRVTEC's Avatar
Default VTEC Pressure Problem
Ok so a quick run down of mods that I have built LS sleeved block with a VTEC head, big turbo etc...
The problem is that when I am in the top of 4th and 5th in a run and the let off I get a CEL that says the VTEC pressure.
So what could be the issue. In 1st-3rd all is ok and 4th only some times I have the problem.
I was thinking about using a thicker oil possible like a 5W40 or 10W40 but it only started doing it after the turbo install. There seems to be no oil pressure problems, and the oil return is no kincked on the turbo.
Any insite would be great.
Thanks
Old May 11, 2003 | 01:31 PM
speedworks's Avatar
Default Re: VTEC Pressure Problem (PWRVTEC)
look and see if the oil pan has been bottomed out. if the pan is to close to the pickup it will do this.
Old May 12, 2003 | 03:47 AM
PWRVTEC's Avatar
Default Re: VTEC Pressure Problem (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">look and see if the oil pan has been bottomed out. if the pan is to close to the pickup it will do this.</TD></TR></TABLE>
Nope oil pan is good....
I even took the pan off to check the pick up, and all is good.
Old May 16, 2003 | 06:31 AM
PWRVTEC's Avatar
Any other ideas....TTT
Old May 16, 2003 | 06:36 AM
DaveF's Avatar
how old is the engine?? possible that teh bearings are screwd?? maybe the vtec sol assm is bad?
sol2hatch
Mar 6, 2006 10:45 AM
Andrewm224
Jul 16, 2005 08:08 PM
specialedition
Sep 16, 2004 08:41 AM
sikek
Aug 10, 2004 05:49 PM
Kamin
Feb 20, 2002 02:35 PM
