vtec head w/ SC possible?
Old Feb 7, 2005 | 05:09 PM
MtnCRX's Avatar
Default vtec head w/ SC possible?
Ive got a JRSC runnin 10 lbs on a pretty much stock crx si and im wondering if its at all possible to stick a D16Y8 vtec head on the car without having to worry about much. I also plan to convert the car to obd1 when i do this so i can run uberdata.
I know i need the y8 head, y8 distributor, y8 head gasket, y8 timing belt, and a obd0-obd1 conv harness. The stock a6 injectors will be switched out for dsm 450's and the pm6 ecu will be changed to the p28.
-Will there be a rise in compression that might affect boost levels/knock? I already have to run 93 oct.
-Also, will the blower hook up to the head without a problem?
Im still in the research stage of this and most write-ups are installs w/ the stock IM, so any help/suggestions are greatly appreciated.
Old Feb 7, 2005 | 05:46 PM
JRciv's Avatar
Default Re: vtec head w/ SC possible? (MtnCRX)
I don't know if the IM ports will match up, but according to this:
http://www.knology.net/~jediklc/D.htm
Compression goes from 9:1 to 10:1. Big difference.
Old Feb 7, 2005 | 08:23 PM
Reedy's Avatar
Default Re: vtec head w/ SC possible? (JRciv)
Should be easily fixed with a cometic head gasket. It alone droped the CR on my b18c from 10.5 to about 9.1.
Old Feb 8, 2005 | 03:38 PM
MtnCRX's Avatar
Default Re: vtec head w/ SC possible? (Reedy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reedy &raquo;</TD></TR><TR><TD CLASS="quote">Should be easily fixed with a cometic head gasket. It alone droped the CR on my b18c from 10.5 to about 9.1.</TD></TR></TABLE>
where did you purchase this headgasket and is there one that will fit my application? Should i be getting a y8 headgasket?
Old Feb 10, 2005 | 07:11 AM
MtnCRX's Avatar
bump
Minime515
Apr 24, 2018 09:52 PM
black7hatch
Nov 15, 2006 05:10 PM
r6samson
Mar 31, 2005 02:37 AM
CRXcracker
Jul 8, 2004 01:16 PM
1994hatch
Apr 7, 2004 05:15 AM
