VTEC feels bad with boost
Old Mar 30, 2003 | 02:07 PM
ludelvr's Avatar
Default VTEC feels bad with boost
So what's the deal with this, is my turbine wheel too small? I have a t3/t4 with an ar of .48 on the turbine and a .6 on the compressor. When VTEC hits it feels pretty bad and almost like it's reached its limit. Anyway, I"m running a JRSC fmu which is like a 5:1 but I've tapped it into the intake manifold so I'll get an extra 5 -10 psi of fuel pressure depending on my IC drop and it's running full rich. I'm just wondering why it feels so flat when VTEC comes on as well as why it sometimes stutters and sputters when giving it full throttle.
Old Mar 30, 2003 | 02:12 PM
wickedxboi's Avatar
Default Re: VTEC feels bad with boost (ludelvr)
what kind of fuel pump are u running? do you have a inline pump with the fmu?
Old Mar 30, 2003 | 02:16 PM
ludelvr's Avatar
Default Re: VTEC feels bad with boost (wickedxboi)
Yup, it's a bosch inline.
Old Mar 30, 2003 | 02:19 PM
SiRkid's Avatar
too much fuel.
jrsc fmu's are really bad for crapping out aswell
[Modified by SiRkid, 11:20 PM 3/30/2003]
Old Mar 30, 2003 | 03:12 PM
b16ahybrid's Avatar
Default Re: VTEC feels bad with boost (SiRkid)
Too rich. I had the same probelm with my setup when i first put the new turbo on.
Once vtec hit the power would stop.
The ecu dumps more fuel once vtec hits so once it switches over your overly rich. I'm also going to bet that your probably to rich throughout the power band.
my experience
8:1 fmu it would pull hard until vtec then it stopped accerating(felt like it was bouncing off the rev limiter
6:1 fmu it would pull hard up to redline felt pretty good. (air/fuel ratio of 10.0 or richer)
4:1 fmu pulles harder and air/fuel ratio of 11.0- 11.5 (before i leaned it out even more with a sfc)
with the 6:1 fmu i made 199whp
4:1 fmu i made 217whp then another 9hp with the fine tuning of the sfc (leaned it out more
Old Mar 30, 2003 | 03:48 PM
92HB_HB's Avatar
your turbo might be the limiting factor as well... w/ such a small turbine housing and so much air being consumed by the vtec head, its not that hard to figure out where the problem lies.. could be ur fueling too..
Old Mar 30, 2003 | 03:53 PM
b16ahybrid's Avatar
Default Re: VTEC feels bad with boost (92HB_HB)
could be, but if the turbo was to small boost would just drop off in the top end vs causing a problem like this.
I ran a smaller turbo (t3 .42 trim) on my b16a and boost would drop off above 5k rpm because it was too small and couldnt flow enough.
anything is possible but a .48 shouldn't be to small (smaller then what i would run)
[Modified by b16ahybrid, 4:54 PM 3/30/2003]
Old Mar 30, 2003 | 04:08 PM
ludelvr's Avatar
Default Re: VTEC feels bad with boost (b16ahybrid)
Well, I changed the boost source back to what I had it and instead of running a boost line from the charge piping before the intercooler, I have now tapped it into a boost source from the intake manifold. It's a bit better but it it is still a bit rich I guess cuz it's still a little wonky.
One question I have is spark plugs as well as oil in the charge pipes. The turbo I had before took a huge dump and there was a **** load of oil in the charge piping and compressor housing. We've replaced the center cartridge but there is still some oil in the charge piping and probably intercooler. The good news is that it's not in the new turbo but there is still some coming out the bov. Could the excess oil that is making it to my plugs and combustioin chamber be causing this fall in hp in addition with the extra rich fueling?
Also, so is it the general consesus that I should decrease my rise rate? I can get access to an adjustable holley one which is from 1:1 and goes up to 4:1 rise rate.
Old Mar 30, 2003 | 04:13 PM
ludelvr's Avatar
Just one other thing...why is that so many people need to run 12:1 or 10:1 fmus and I'm running too rich with a 5:1? Is it because my injectors are that much bigger? I've heard that they are anywhere from 310's to 345's but in any case, why would I be running too rich with a 5:1?
Old Mar 30, 2003 | 04:20 PM
ludelvr's Avatar
my experience
What injectors were u using with the 4:1 fmu and what fmu? the vortech?
Old Mar 30, 2003 | 06:01 PM
legendboy's Avatar
I figured that it is the turbine too, I was running the same size on my integra with the hack and I was getting a similar problem, I had to shift gears around 6k
[Modified by legendboy, 8:04 PM 3/30/2003]
Old Mar 30, 2003 | 06:11 PM
ludelvr's Avatar
Default Re: VTEC feels bad with boost (legendboy)
So you think it's entirely the turbine wheel being too small or do you think it has something to do with it being too rich?
Old Mar 30, 2003 | 06:43 PM
SiRkid's Avatar
NO.
its not your turbo.
id say its a fuel problem!
get rid of that jackson pos.
Old Mar 30, 2003 | 07:16 PM
b16ahybrid's Avatar
310cc rc injectors.
Most people run a 8:1 vortec fmu with 310cc injectors just fine.
I was skeptical about runing even the 6:1 fmu but i tried it and it helped. I eventually ended up with the 4:1 because the 6:1 was still to rich. I know this for a fact because my car has been tuned on a dyno with a wide band o2 sensor so i know my air/fuel ratio readings are accurate.
Old Mar 30, 2003 | 07:39 PM
ludelvr's Avatar
NO.
its not your turbo.
so are you saying get rid of just the jrsc fmu or ditch the fmu entirely? I know that I should be going with a standalone but for now, the fmu will have to do...with this in mind, do you recommend going with a smaller rise rate?
Old Mar 30, 2003 | 07:42 PM
ludelvr's Avatar
Oh yah, one other thing, I'm currently running stock plugs with stock gap...do you guys think this will have a huge bearing on why my setup is running the way it is?
Old Mar 30, 2003 | 08:14 PM
b16ahybrid's Avatar
shorten the gap. you have mail
Old Mar 31, 2003 | 10:49 AM
ludelvr's Avatar
Other things that I'm wondering are firstly, could my inline fuel pump be causing me to go over rich? Would there be any benefit for me to take out my inline and just run my stock fuel pump with the jrsc fmu?
Secondly, if it is the vtec that is causing too much fuel, would there be an upside to turning off vtec and if so, how can I simply turn off vtec? Is there a wire I can make a switch for or something?
Old Mar 31, 2003 | 11:22 AM
Diego Boost's Avatar
NO.
its not your turbo.
Ditto that. I was having the same problem before I got my hondata. When vtec would kick it it would bog for about 600 rpm and then it would start to build power very quickly.
imskatencrzy
Apr 3, 2007 05:01 PM
lloydadvance
Oct 23, 2005 12:51 PM
shotty
Jul 22, 2003 08:44 AM
91projecthatch
May 5, 2003 12:56 PM
turbob16
Apr 1, 2003 06:51 PM
