Vortech Type R Problems help
Old Aug 28, 2004 | 06:02 PM
98-0688's Avatar
Default Vortech Type R Problems help
98 type r
mods are
rc 310 injectors
vortech FMU
aem Fuel pressure Regulator
vafc2 controller
3inch Thermal exhaust
test pipe
jdm 4-1 header
msd 6al BTM
also the fan in the supercharger turns a little bit. is that a problem or is it supposed to do it?
i have no fuel pump
no air filter
no oil cooler air cooler.
i have the power cooler and a dump tube going to the oil pan
as soon as vtec engages it backfires and shoots a flame out. i can only do about 30% throttle without it bogging out and backfiring.
what could be the problem with the car?
Old Aug 28, 2004 | 07:52 PM
Bbasso's Avatar
Default Re: Vortech Type R Problems help (98-0688)
Did you ever have it tuned by a pro?
Old Aug 28, 2004 | 08:17 PM
hadboosttroy's Avatar
doesnt your car have an oil cooler stock? I'd also get an air filter asap. I wouldn't even drive w/o one. Mess around with your vafc settings I guess, but you should take it to a pro, because that is otherwise a recipe for disaster.
Old Aug 28, 2004 | 08:40 PM
98-0688's Avatar
Default Re: Vortech Type R Problems help (hadboosttroy)
its tuned but not dyno tuned.
Old Aug 28, 2004 | 10:52 PM
Chubz's Avatar
put a filter on that, also your timing must be screwed up and you are probably running lean. i would get a fuel pump as well 255lph and prolly ditch the 310s and go with 440 saturated injectors. Also Hondata or AEM EMS to have that setup running right. Sounds to me like you having major issues, and it takes no genious to figure out your running lean. It wont be to much longer if u keep driving it this way that youll damage your motor.
Old Aug 29, 2004 | 04:48 AM
Dropspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-0688 &raquo;</TD></TR><TR><TD CLASS="quote">its tuned but not dyno tuned. </TD></TR></TABLE>
I would revisit your "tuner" or find a new one to start.
Mattj
Old Aug 29, 2004 | 07:35 AM
1028R's Avatar
u need a fuel pump and a retard box for your timing. or u coul sell everything to me i could make it work on my R.
Old Aug 29, 2004 | 07:46 AM
1GreyTeg's Avatar
What the Hell is "Tuned, but not Dyno tuned"?
What did you use a tuning fork?
Explain please...
Old Aug 29, 2004 | 07:56 AM
ATgrills.com's Avatar
Default Re: Vortech Type R Problems help (1GreyTeg)
i wanna see a pic!
Old Aug 29, 2004 | 05:39 PM
98-0688's Avatar
Default Re: Vortech Type R Problems help (ATgrills.com)
going back in shop tonight and hes gona work on it some more so ill find out this week.
Old Aug 29, 2004 | 05:44 PM
Padawan's Avatar
Darth ModerVader
Default Re: Vortech Type R Problems help (Chubzilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote">put a filter on that, also your timing must be screwed up and you are probably running lean. i would get a fuel pump as well 255lph and prolly ditch the 310s and go with 440 saturated injectors. Also Hondata or AEM EMS to have that setup running right. Sounds to me like you having major issues, and it takes no genious to figure out your running lean. It wont be to much longer if u keep driving it this way that youll damage your motor.</TD></TR></TABLE>
It actually sounds to me like a rich condition. All of that unburned fuel passing through to the exhaust and igniting. I'll agree that it's in major need of some professional tuning though.
Old Aug 29, 2004 | 07:49 PM
Chubz's Avatar
Default Re: Vortech Type R Problems help (Padawan)
are or were u still at stock fuel pressure
Old Aug 30, 2004 | 07:57 AM
Big Phat R's Avatar
also <u>the fan in the supercharger</u> turns a little bit. is that a problem or is it supposed to do it??</TD></TR></TABLE>
if yours has a "fan" in it - I would send it back
Old Aug 30, 2004 | 08:27 AM
Finland's Avatar
If you are running a 1:12 FMU and 310 cc injectors and less than 10Psig boost, it's probably rich. Sounds like the ECU is pulling timing (therefore igniting an already rich mixture in the exhaust manifold)...BTW FMU is not considered tuning....you need Hondata, or AEM
Old Aug 30, 2004 | 08:54 AM
98-0688's Avatar
Default Re: (boost psycho)
so to fix the running rich problem what would i do?
Old Aug 30, 2004 | 08:57 AM
Padawan's Avatar
Darth ModerVader
Default Re: (98-0688)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-0688 &raquo;</TD></TR><TR><TD CLASS="quote">so to fix the running rich problem what would i do?</TD></TR></TABLE>
Have it tuned by a professional, preferably one who has access to a dyno with a wideband O2.
Old Aug 30, 2004 | 08:58 AM
98-0688's Avatar
Default Re: (Padawan)
i am when i get a fuel pressure gauge, put the stock cat back on, fix one oil leak, and put the fuel pump in.
Old Aug 30, 2004 | 10:25 AM
RTW DC2R's Avatar
I just bought a brand new M5, and I put on a 400 shot of naws and a FPR. For some reason my car is running like doodie. can someone help?
why people waste their time and our time by half assing **** is beyond me. get a freaking clue before you go making your car mad fast y0.
Old Aug 30, 2004 | 12:45 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Explain please...</TD></TR></TABLE>
you can still tune without a dyno.. no sure what happend in his case..
Old Aug 30, 2004 | 12:55 PM
98-0688's Avatar
Default Re: Vortech Type R Problems help (vtec.dc2)
im not trying to half *** this job. im asking you all for help. i pretty much bought top of the line everything for this car. the guy that tuned it knows how to tune it without a dyno. he will get it close enough so i can drive it an hour n half away for a dyno tune. im just asking you all for help. so please dont talk **** about it. thanks
Brian
Old Aug 30, 2004 | 01:03 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-0688 &raquo;</TD></TR><TR><TD CLASS="quote">im not trying to half *** this job. im asking you all for help. i pretty much bought top of the line everything for this car. the guy that tuned it knows how to tune it without a dyno. he will get it close enough so i can drive it an hour n half away for a dyno tune. im just asking you all for help. so please dont talk **** about it. thanks
Brian</TD></TR></TABLE>
1. you're supposed to run inline fuel pump with fmu
2. fmu is not top of the line.. standalone will do a better job, that and adding a intank fuel pump
3. don't beat on the car until you come up with solution for this problem
4. did your tuner use wideband? it could very well be runing lean without enough fuel.
5. i'm sure you're planning to add a filter, i'd suggest to do that asap before damaging stuff.
6. stock ignition will do just fine for supercharger hp, you can get some money back by selling msd
Old Aug 30, 2004 | 01:07 PM
98-0688's Avatar
1. i got a walbro 255hp pump. which was faulty so im waiting on the new one to come
2. fmu came with the kit. i have a vafc2 that i am also using with the kit.
3. i have only done 35% throttle on the car so far. but car is in shop again.
4. no wideband yet. until i get everythign installed on it
5. buying a hks mushroom filter. only one that will fit due to the abs on a type r.
6. i dont need a btm on the car?
Old Aug 30, 2004 | 01:19 PM
vtec.dc2's Avatar
i'm running 260whp and no problems (turbocharged).. i still plan to use stock ignitionafter i up the hp to 325whp (ignition is all stock but not the spark plugs).. i'm also running hondata with 550's injectors, f.p.r., intank 255 pump, its tuned with wideband through entire powerband.. the more hp you run, the easier its to blow the motor.. you may do fine with vafc, but make sure its tuned well.. if tuned well, you shouldn't have problems you have right now. wideband only needed to tune the car.
Old Aug 30, 2004 | 01:22 PM
98-0688's Avatar
i have a CEL but dont know what code yet cuz its in the shop. says i dont have enough back pressure due to 3in exhaust and a test pipe. so i have to either modify my stock cat or get a carsound cat. i got the oil leak fixed. still have to get a dyno tune on the car. and the fuel pressure set right and the fuel pump installed.
Old Aug 30, 2004 | 01:28 PM
[jdm ap2]'s Avatar
Default Re: Vortech Type R Problems help (Dropspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Mattj</TD></TR></TABLE>
alperx
Jun 7, 2012 08:41 PM
98-0688
Aug 28, 2004 08:40 PM
Triv
Jun 3, 2004 07:24 AM
BDiddy
Apr 18, 2002 07:42 AM
