Vortech charged B16 on 3 cylinders...
Old Oct 28, 2002 | 01:49 PM
xrtdac
Guest
Posts: n/a
Default Vortech charged B16 on 3 cylinders...
supposively made 240 to the ground on the dyno. the funny part is that the shop that did the dyno work said that car was running fine and that there was no way that engine could prodcue those numbers on 3 cylinders with just a charger.
The funniest part is that the guys friend was runnin around telling people that he made 240 to teh ground on only 2 cylinders. It was found out that it supposively was made on 3 cylinders only cause when they did a compression check this past week, a month after the dyno time, one cylinder had 0 compression.
Now the guy who owns the car is tryin to say that he will make 300 to the ground on a stock internal B16 with the vortech charger on it. As well as he thinks it will be fine and not break rods or crack a sleeve.
Anyone have any thoughts on this??
[Modified by xrtdac, 2:49 PM 10/28/2002]
Old Oct 28, 2002 | 01:54 PM
Etylorcen's Avatar
Default Re: Vortech charged B16 on 3 cylinders... (xrtdac)
Im thinking it made 240 on the dyno and later the cylinder lost compression.
Old Oct 28, 2002 | 01:55 PM
xrtdac
Guest
Posts: n/a
Default Re: Vortech charged B16 on 3 cylinders... (Etylorcen)
thats what my thoughts were but this kid is stuck on the thought that it made those numbers on 3 cylinders working only.
[Modified by xrtdac, 2:55 PM 10/28/2002]
Old Oct 28, 2002 | 01:56 PM
buddha429's Avatar
Old Oct 28, 2002 | 02:15 PM
xrtdac
Guest
Posts: n/a
Default Re: Vortech charged B16 on 3 cylinders... (buddha429)
another side question, any thoughts as to how much HP to the wheels the B16 can really handle before it cracks a rod or spins a bearing or screws up a sleeve or somethin?
[Modified by xrtdac, 3:16 PM 10/28/2002]
Old Oct 28, 2002 | 04:00 PM
HybridKOOP's Avatar
That could happen at 140whp... or it could NOT happen at 400whp.
T-u-n-i-n-g.
Old Oct 29, 2002 | 09:03 AM
xrtdac
Guest
Posts: n/a
Default Re: Vortech charged B16 on 3 cylinders... (HybridKOOP)
yeah but simple physics of the metals used will determine how much pressure they can take. Tuning a LS to 400HP wont happen cause the rods will break as well as the sleeves wont handle it. you can only push stock internals soo far. and tuning it alone is not going to make it safe when the metals can't handle the pressure or power.
Old Oct 31, 2002 | 04:29 AM
mjrage's Avatar
Did he replace any internals at all our just slapped the vortech on? Vortech's site boasts 277 hp with a stock si and aftercooled vortech.
Old Oct 31, 2002 | 04:56 AM
OKSolSi's Avatar
T-u-n-i-n-g.
I hate people like you who think tuning can turn iron into the strongest metal in the universe. Shut the **** up you mindless ****.
[Modified by OKSolSi, 1:57 PM 10/31/2002]
Old Oct 31, 2002 | 05:18 AM
clendaniel's Avatar
Default Re: Vortech charged B16 on 3 cylinders... (mjrage)
I was curious as to vortech's claims also...I installed and tuned a friend's setup just so that I could get that puppy on the dyno and see what it did. It's a B16B in a '97 hatch w/ a modified aftercooled SI setup, kamikaze header, testpipe, and a 3" thermal running the AFC hack w/ DSM 450s. As you can see from the dyno his setup was right with vortech's claims with one of the ugliest curves you'll see. I have a feeling vortech's numbers were uncorrected and possibly "enhanced" as drew's setup put down 288hp STD but only 276hp SAE with alot more than just the charger on a stock SI.
--Ian
Old Oct 31, 2002 | 06:36 AM
dbman96's Avatar
New User
Detonation breaks rods AND sleeves. True it is POSSIBLE to crack a sleeve from simple pressure loading but I would bet 99% of the cases where people claim they're tuned "perfectly" and still break a rod or sleeve, they're detonating and just don't know it. All it takes is one cylinder running leaner than the other 3; your wideband will still think you're fine. You're also MUCH more likely to snap an LS rod by over-revving it than by boosting it.
Old Oct 31, 2002 | 06:57 AM
SiRkid's Avatar
supposively
SU..WHAT??????????????????
Old Oct 31, 2002 | 09:04 AM
lazerus's Avatar
Default Re: Vortech charged B16 on 3 cylinders... (SiRkid)
Stock cyl's can only take so much, in honda sleves case, that's usually not very much!
though the little 1.6L isuzu motors i use are nearly indestrucable in stock form.
Tuning goes a long way, but so does a nice set of aftermarket bottom end parts.
And EWWW That power curve is NASTY! Yuck!
Old Oct 31, 2002 | 12:17 PM
94CivicSir's Avatar
The 277 hp claimed by Vortech is at the flywheel and not at the wheels. I've seen most people make 230-240 at the wheels which is about right with drivetrain loss.
Old Oct 31, 2002 | 02:20 PM
Loco Honkey's Avatar
Default Re: Vortech charged B16 on 3 cylinders... (lazerus)
Yeah, you'll have that when you use a centrifugal supercharger. Why the hell people use these pieces of **** is totally beyond me...
Old Oct 31, 2002 | 03:13 PM
BoostedH23a1's Avatar
Default Re: Vortech charged B16 on 3 cylinders... (House of Boost)
little off topic but i got a h23 prelude with t3/t4b turbo. got intercooler, rev hard mani and downpipe 2.5 inch exhuast, cams, cam gears , igintion, coil and wires. what do u think i will dyno at 7psi. all motor it hit 163hp read my sig..
Old Oct 31, 2002 | 03:20 PM
Finest's Avatar
Default Re: Vortech charged B16 on 3 cylinders... (OKSolSi)
WTF?! What crawled in your panties?
Tuning may not turn iron into the strongest metal, but it does prevent it from turning into a molten block.
BTW, for the H23 turbo guy. That turbo is a bit undersized for a 2.3L. Not saying that it won't work, just that it'll peak earlier and spool like a *****. Good luck, and keep us posted.
Old Nov 1, 2002 | 11:22 AM
xrtdac
Guest
Posts: n/a
Default Re: Vortech charged B16 on 3 cylinders... (Prelude_RCR)
I think the t3/t4 turbo is about right for that H23.
I would guesstimate you make 245HP to the ground and maybe 215 torque due to the faster spool up. (9psi)
My dyno looked pretty:
****** A I HATE CLUB PHOTO. everytime I try and link a pic from them tnow, it changes into that stupid 25 cent print ****** picture. aaaaaaaaaaaaaaaaaaaaaaaaaaaa
[Modified by xrtdac, 12:23 PM 11/1/2002]
[Modified by xrtdac, 2:37 PM 11/2/2002]
Old Nov 1, 2002 | 12:47 PM
integra-modder's Avatar
youd prob want a t3/to4e, not b.
Old Nov 3, 2002 | 11:38 AM
xrtdac
Guest
Posts: n/a
Default Re: Vortech charged B16 on 3 cylinders... (integra-modder)
yeah he could use that, but thats what I got. He would probably never build the motor for awhile so the B is plenty enough for right now is my guess.
Old Nov 3, 2002 | 12:03 PM
yea im still in college so im broke. damn sleeving cost so ****** much. its gonna be 1700 just to build the block in parts + labor.. i guess really all i have to have done is the sleeving i can do the rest.
Old Nov 3, 2002 | 10:01 PM
xrtdac
Guest
Posts: n/a
Default Re: Vortech charged B16 on 3 cylinders... (BoostedH23a1)
I feel ya there. I have a guy who has an AEBS built GSR motor sitting and doing nothing. I want it. but he wont sell it. GA. Its so close I can tatse it. oooo how nice it woudl be to be able to run 30-35 psi. oooohhh child.
Mjalaly
May 25, 2016 07:37 PM
hondakevin21
16
Apr 25, 2006 07:43 PM
volkdlr
12
Jul 8, 2005 09:08 PM
RICE POLICE SIP
14
Apr 30, 2003 08:02 PM
LsTurbo91
Jun 19, 2002 03:19 PM
