Turbo b16 engine popped on the dyno
Subscribe
Jul 25, 2015 | 06:58 PM
So yeah cylinder 1 (completly gone), cylinder 2 low compression about to go. All at 180 before dyno day. The tune looked good, as far as i know. There wasnt much timimng in it.. 17 i think and the engine just popped. It pulled 235 hp 180ftlbs on 9lbs right before she went which seems really low to me. Spool up was also around 3500rpm which seemed a bit slow.
Build
Stock block
Hondata s300
Gt32 turbo,
Spoolin Performance log mani
RC 650 cc injectors
resignator right off turbo to straight through exhaust (nothing else)
Tial f38
walbro 255
Omni valve train
stock b16 cams
Tuning shop is one of the best in colorado so i dont think anything on the tuning side was bad.
Thoughts??
Right now its at the shop for a bottem end build
aries pistons/rings
Arp rod bolts
adding a mac valve to spool up faster
I will attach dyno video in the morning
Reply 0
Jul 25, 2015 | 07:31 PM
Re: Turbo b16 engine popped on the dyno
180 PSI seems a lil low for a B16
Reply 0
Jul 25, 2015 | 07:39 PM
So whats the point of the thread?
No pics.
Youre already rebuilding and using the same tuner.
Do you haz questions?
Reply 0
Jul 25, 2015 | 08:08 PM
Trying to figure out what happens so that the new engine doesn't pop. Seems odd that it would go so easy with little boost and power. I have seen stock blocks hold up with much bigger turbos running more boost.
Reply 0
Jul 26, 2015 | 01:03 AM
Quote: Trying to figure out what happens so that the new engine doesn't pop. Seems odd that it would go so easy with little boost and power. I have seen stock blocks hold up with much bigger turbos running more boost.
sounds pretty normal to me. 9lbs is just about the limit of what a stock block can handle. Rings are usually the first thing to go on a stock block
Reply 0
Jul 26, 2015 | 01:07 AM
A GT32, on a B16? Does someone else thing that seems...oversized?
Reply 0
Jul 26, 2015 | 04:20 AM
Quote: 180 PSI seems a lil low for a B16
Compression has alot of factors and I would assume the elevation of colorado has a role of why its a little on the low side.. as long as they were even across the board..
Reply 0
Jul 26, 2015 | 05:18 AM
Need to see pics man.
It could be a bunch of different things. We can only guess what the cause was if we see pics
Reply 0
Jul 26, 2015 | 06:05 AM
your last thread said your compression was between 170-180 i believe. even then i said that sounds low for a b16, considering my completely stock b16 made 220ish across the board. and my 9:0.1 motor makes over 180 compression. yes coloardo elevation is higher, but that big of a difference. and yes pics please.
couldve just been a casting flaw. or an air bubble pocket near the ringlands. lots of cases
Reply 0
Jul 26, 2015 | 06:31 AM
Quote: A GT32, on a B16? Does someone else thing that seems...oversized?
Only yourself. The GT32 is actually smaller than a GT30, despite its nomenclature.
Reply 0
Jul 26, 2015 | 08:00 AM
Once i get pics of the parts i will post pics but i am sure the rings went.
I figured 9lbs would create more power but if most of it was being lost though blow by, i guess not.
Dyno video of 1st run with 174hp
Reply 0
Jul 26, 2015 | 10:07 AM
There are a lot of factors.. Most of it is prior health of the stock engine. The tests you performed give you information initially, but don't conclude that b16s can not handle the 300whp threshold that your research had led you to believe here. Many factors including tuning play a large role.. The tuning was fine, but the health of the engine wasn't.
Also, don't get into this psi logic again. 9 psi or 11 psi doesn't make the difference. It could have stayed at 9 and lasted through your tuning session, only to die a week later..
But that is now moot.
Reply 0
Jul 26, 2015 | 10:19 AM
Quote: There are a lot of factors.. Most of it is prior health of the stock engine. The tests you performed give you information initially, but don't conclude that b16s can not handle the 300whp threshold that your research had led you to believe here. Many factors including tuning play a large role.. The tuning was fine, but the health of the engine wasn't.
So can i shoot for 300hp+ with 9.4 compression pistons, rings anf arp rod bolts? Any thing
else need to change? Not sure if the IAT were low enough either.
I think this is the correct compressor map for my turbo. Keep in mind this car is desinged for track racing not drag racing.
http://turbobygarrett.com/turbobygar...2203-1comp.jpg
Thoughts maybe on optimizing everthing?
Reply 0
Jul 26, 2015 | 10:46 AM
Quote: Only yourself. The GT32 is actually smaller than a GT30, despite its nomenclature.
Ah, OK, that's the part I didn't know. Disregard me, then
Reply 0
Jul 26, 2015 | 10:51 AM
Quote: So can i shoot for 300hp+ with 9.4 compression pistons, rings anf arp rod bolts? Any thing
You're fine with that compression and turbocharger. Try not to go lower in static compression. don't fall for the "lower CR is better for boost" logic... that logic is fraught with fallacies.
Also, when there is no good effective compression due to bad ringlands, it affects the turbocharger negatively, and showing there is a problem by the turbocharger not responding very well to your dyno. ALWAYS run a filter no matter what.
This is also a good time during the rebuild to flush the entire oil system out, because you don't know what contaminants or babbit may have befallen your oil lines. Since its being built, check your oil pan, flush the turbo oil lines both feed and return lines, (even if they don't show signs of any metal or other babbit material. This is essential!!! I've seen a lot of people blow up one engine with the turbocharger being perfectly fine, then go to another engine, and the turbo starts experiencing problems from the old engine, because they swapped over the same equipment to the new engine, and didn't flush the lines and check for signs of metal shavings or babbit. Do that first and foremost.
Reply 0
Jul 26, 2015 | 11:13 AM
Quote: Once i get pics of the parts i will post pics but i am sure the rings went.
Dyno run - YouTube
Look at all that smoke that its blowing
How much timing was in it above 6k rpm Or peak tq?
Im guessing detontation cracked your ringlands
Reply 0
Jul 26, 2015 | 11:14 AM
What ems?
Reply 0
Jul 26, 2015 | 11:43 AM
I will need to check on timing but he mentioned he hadn't even started to put timing in yet.
Ems is hondata s300
Reply 0
Jul 26, 2015 | 11:44 AM
This....There is a LOT of smoke coming out on that video...Should have stopped as soon as you saw there. You can't tell me with 3 people aside from the driver no one saw that smoke?
Reply 0
Jul 26, 2015 | 11:49 AM
That smoke has always been there even before the turbo was really boosting. We figured it was just excessive blow by or oil being pushed in through the valves. Only happened when reved really hard. And it was more like 8-12 people
Apart from hindsight (rings or pistone crap out on a not healthy engine)... Anything else I should consider apart from pistons /rings, rod studs and oil flush?
Should I try to decrease the air temp with a fan or something?
Reply 0
Jul 26, 2015 | 12:12 PM
Stock block b16s can handle like 350whp
Post your map
Did you maybe have 87 octane gas in there? Did it run lean at all? Are the injectors new? Have they been cleaned and flow tested if they are used?
Was the tuner datalogging? If he did take a look at the logs. How rich was the afr? Did he read your plugs at all during this?
Reply 0
Jul 26, 2015 | 12:13 PM
And def post more pics of that little car you have idk what it is but im ******* intrigued
Reply 0
Jul 26, 2015 | 01:16 PM
I will need to get the maps from the tunner.
He data logged and we checked the plugs during tunning. I didn't see it go lean at all during the tuning process or during runs.
Injectors are not new.
Fresh 4 gal of 91 in there. Best we can get out here on the pump (except e85 but that's hard to come by)
Reply 0
Jul 26, 2015 | 01:31 PM
Pics
Last one is what it will look like once I can finish the molds for the carbon body work
Reply 0
Jul 26, 2015 | 02:29 PM
Man that thing looks sweet! Slap a K20 in that bad boy!!!
Reply 0
