B16 Dyno
Old Jun 16, 2002 | 12:50 AM
LsTurbo91's Avatar
Default B16 Dyno
Here's my dyno from friday, not too bad. I wasn't expecting much from this b16. 170'ish across the cylinders from the compression test. Don't mind the A/F ratio heh, its all over the place I didn't really care too much for that run. The DIY wideband vs there tail sniffer was pretty much accurate as far as my 8psi run. The wideband at the shop read a lil leaner, the DIY was reading around 11.6-11.8:1 while the shops, 11.9-12.0:1.
The dyno operator left and let this guy drive my car that didn't know how to drive a stick all that well My car felt like it was gonna fly off the dyno, he kept stalling/jerking . He kept flooring my car 1st and 2nd like he was freaking racing on the dyno lol. I wanted to get out of there asap heh.
Specs:
Stock B16 Head/block
11psi
16 base/20deg up top - this one doesn't like a whole lot of timing too
even with a 100octane hmm.
T3/To4e 50trim
Old Jun 16, 2002 | 12:56 AM
BoostinDC2's Avatar
Default Re: B16 Dyno (LsTurbo91)
nice numbers. sucks about the guy who didnt know crap.
Old Jun 16, 2002 | 03:05 AM
qwkteg125's Avatar
Default Re: B16 Dyno (BoostinDC2)
wow kab not bad for a "torqueless" b16 motor that you said seemed weak
Old Jun 16, 2002 | 05:46 AM
lsvtec101's Avatar
Default Re: B16 Dyno (qwkteg125)
nice! cant wait to see what my 10psi LS motor will pull shop down the road just installed a nice 1000hp dyno :D :D i could **** on the joint from my crib lol!
Old Jun 16, 2002 | 12:57 PM
LsTurbo91's Avatar
Yea, I wasn't really expecting much but turned out ok. We'll see how it does saturday. I think i'll turn up the boost though maybe 13-14lbs .
Old Jun 16, 2002 | 01:19 PM
SiR Kid's Avatar
New User
NIIIICE DYNO! I just hope my motor makes that kind of power this time around!
Old Jun 18, 2002 | 07:51 PM
easy jesus_151's Avatar
Default Re: B16 Dyno (SiR Kid)
nice
Old Jun 18, 2002 | 08:49 PM
Conechaser's Avatar
Default Re: B16 Dyno (erknjerk151)
I'm blind whats the numbers?
Also what is your setup?
My friend has a built turbo b16. 9:1 CR
Drag Gen III Kit ~11psi on pump gas
550cc injectors
AEM EMS
Nothing else to mential really, hopefully next month or so when the dyno opens up here we'll see what it puts down, it trapped 85mph in the 1/8 mile spinning the whole way on 17" street tires, so we know it has some power.
Old Jun 18, 2002 | 09:08 PM
Ri5e's Avatar
Default Re: B16 Dyno (94Accord)
From waht I can see, it looks like its not breaking the 200 ft-lb barrier.
How much WHP is that? Its so tiny...I might be blind or something.
Also, 11 psi with stock compression???
Old Jun 18, 2002 | 09:22 PM
rjardy's Avatar
Default Re: B16 Dyno (BG Boost)
Nice numbers guy
Rob
Old Jun 18, 2002 | 09:30 PM
LsTurbo91's Avatar
Can you see it now?
Old Jun 18, 2002 | 09:36 PM
lucas569's Avatar
THE PIC is too small!
Old Jun 19, 2002 | 06:20 AM
Giuseppe's Avatar
Can you see it now?
nope.!!
Old Jun 19, 2002 | 07:52 AM
Speed PHreak's Avatar
I wanna see, I wanna see! 170 for the compression? that's a bit low for a b16. My LS has 185 across the board......Maybe thats why it's weak feeling?
Old Jun 19, 2002 | 01:37 PM
LsTurbo91's Avatar
Default Re: B16 Dyno (Speed PHreak)
http://www.imagestation.com/album/?id=4292266355
Old Jun 19, 2002 | 03:19 PM
SiRkid's Avatar
ummm....yeah...id wager that that aint too bad at all!!!!!!!
271WHP and 198 lbs-ft for 1.6L (about 100 lbs-ft over stock and 140hp) sweet!!
itll be faster than an ls!
[Modified by SiRkid, 12:19 AM 6/20/2002]
[Modified by SiRkid, 12:20 AM 6/20/2002]
Drew17th
Jan 7, 2013 08:05 AM
FATBOYeg6
Jun 16, 2007 07:03 AM
volkdlr
12
Jul 8, 2005 09:08 PM
The ZC
Jan 5, 2005 09:41 PM
Fred n J_v2.0
Feb 23, 2003 08:50 PM
