Vortech BOV problem
Old Oct 27, 2010 | 12:48 PM
Dave.HR's Avatar
Default Vortech BOV problem
I have a Vortech BOV just like this one:
The problem is that as soon as I connect the Vacuum line to it when the engine is running in neutral, it OPENS WIDE immediately.
Everybody says it's not normal, but I would like your opinion because it doesn't look to me like it's malfunctioning.
While opening the throttle all the way when the car is in neutral the BOV stays equally open.
What I can't see is, does it close while I'm driving the car and boosting it properly.
Old Oct 28, 2010 | 08:45 AM
dpetro1's Avatar
Default Re: Vortech BOV problem
as a former vortech bov owner i can confirm that the bov will be open at idle. it should close as vacuum decreased and should definitely be closed under boost. if it wasnt closing under boost then you would have a major boost leak. also you can adjust the bov by loosening the jam nut and using an allen wrench to tighten the adjustment screw. make sure the adjuster doesnt go lower than 1/8" from the top of the jam nut
here's a link to the instructions, see #6
http://www.vortechsuperchargers.com/.../8d20400im.pdf
Old Oct 28, 2010 | 01:03 PM
Dave.HR's Avatar
By Idle you mean not opening the throttle while the car is in neutral?
Anyway, I've tried boosting the car in neutral but nothing moves in the BOV.
I know all about adjusting it, but if the BOV is fully open, adjusting just won't do! :/
Old Oct 29, 2010 | 05:32 AM
dpetro1's Avatar
lol, yes generally idling would mean the engine is running, the car is a stop and your foot isnt on the gas
your car will not build boost while in neutral. does the bov work properly when driving? does it blow off clean? are you experiencing any boost leaks?
IMO, if the car is running properly and the BOV is working then you are fine and don't need to worry about it.
boosted_duece
Nov 23, 2005 09:29 PM
CRXdan
Dec 11, 2004 10:38 PM
oemDC2
Feb 26, 2004 08:03 PM
wickedxboi
May 21, 2003 08:33 PM
TheIntegraGuy
Dec 2, 2002 11:32 AM
