Victor X or Skunk2 IM for b18b
New User
Not sure if this topic has been already discussed, didn't find much info for b18b motor. Since my motor is currently stock, i'm debating with to get for christmas
any noticable gain over the stock b18b IM with the two?
setup
revhard II t3/t4b
rc 440 injectors
safc
warbro 255hp
msd dig6
8 psi
setup
revhard II t3/t4b
rc 440 injectors
safc
warbro 255hp
msd dig6
8 psi
HT's Biggest Loser
Re: Victor X or Skunk2 IM for b18b (Armani692)
i dunno, but ive heard plenty of good stufff about the JG manifold, and i would suggest purchasing that one instead of the skunk one. good luck..
Re: Victor X or Skunk2 IM for b18b (boostedcvc)
skunk2 is a constant perfromer, made for mid to high range power. The victorx is made for power gains 7k+ and with a B18 you dont wanna go much higher then 8k.... so take your pick.
Blaze
Blaze
Re: Victor X or Skunk2 IM for b18b (Blaze45)
You also could get your stock one port and polished, see how that works for now...then once you go higher boost and get something a little bigger
New User
since my motor is pretty much stock...
i'll be running 8psi max with 440 injectors
So i guess the b18b won't benefit much from victor x IM unless i buildup the motor with valve springs and retainers.
thanks guys
So will i notice any significant gain over the stock b18b IM with the skunk2
thanks guys
what about a B20nonVtec at .8bar and 7500RPM redline??? Im so tempted to get the Vector X, but am worried that it will just be a waist of money...and just add to the bling bling factor of my pretty motor...
Re: Victor X or Skunk2 IM for b18b (InfamousRS)
I wouldn't go with the victor x on an ls. It's very important to have a good combonation. The ls motor really shines in the lower rpms and to install a manifold designed for high rpms would hurt performance more than it would help. If your ls was built for high hp and high rpm it would be a different story. I really wouldn't even put the skunk 2 on there unless you plan to rev higher. Stick with what you've got. If you want more power, turn the boost up 1psi!
eg crunkmonster
11-04-2013 07:53 AM
