Velocity stack for turbo
Old Jun 19, 2003 | 08:42 PM
  #26
tony1's Avatar
Default Re: Velocity stack for turbo (boosted hybrid)
Right, a for a velocity stack to really be effective in an intake manifold it should be raised off the floor as pictured above. Without them there is said to be quite a loss.
Old Jun 19, 2003 | 08:50 PM
  #27
done's Avatar
Default Re: Velocity stack for turbo (tony1)
Do velocity stacks still fitler the air??? i know supras run them.. also
Old Jun 19, 2003 | 09:30 PM
  #28
boosted hybrid's Avatar
Default Re: Velocity stack for turbo (Jordo)
Velocity stacks on a turbo dont filter the air in the least. You would have to rig up a screen mesh to cover the inlet area between the end of the inlet, and beginning of the velocity stack. Honestly, they wont make much if any difference. On intake manifolds they do, on turbo's they dont. Now modifying the compressor housing tolerances to enduce a more laminar flow has a profound effect on efficiency and power...
Old Jun 20, 2003 | 04:57 AM
  #29
DC2R714's Avatar
Jeff what about attaching some type of intake tube of a certain length that connects to the velocity stack? Would that cause any effect to the air flow? Would it have to be straight or could it have curves. I like the idea of having velocity stacks in an intake manifold. Kind of like the idea of ITB's.
Old Jun 20, 2003 | 05:02 AM
  #30
Tinker219's Avatar
Default Re: Velocity stack for turbo (DC2R714)
I need a big Velocity stack for my applicationn Ill put a screen mesh over the opening, and the rest of the bumper will be blocked off for optimal airflow to the turbo
Old Jun 20, 2003 | 05:11 AM
  #31
PM-Performance's Avatar
Jeff let me know if you need one . Frank makes thme for all the big dags outta carbon fiber. Matt Scrantons front end for the Celica is down there now. getting dual carbon stacks made for it . I dont think its gonna be any kind of huge noticable difference, but thye loko dope and maybe clean up the air flow going into the turbo inlet.
Old Jun 20, 2003 | 05:14 AM
  #32
DC2R714's Avatar
Default Re: Velocity stack for turbo (itr206)
Pete how much he want for them? I would be interested.
Old Jun 20, 2003 | 05:32 AM
  #33
dunno , ill check with him this weekend. all the ones he has made are for Y2K's, i gotta see for ours. im sure not too much .
Old Jun 20, 2003 | 05:33 AM
  #34
ricodemus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Jeff what about attaching some type of intake tube of a certain length that connects to the velocity stack? Would that cause any effect to the air flow? Would it have to be straight or could it have curves. I like the idea of having velocity stacks in an intake manifold. Kind of like the idea of ITB's.</TD></TR></TABLE>
I think it would have to be straight, since curves would make the fluid travel at a different velocity through the cross-section of the curve. This may or may not cause turbulence at some part of the airflow through the curve. Of course, this would be a worst case where the curve is very close to the turbo's inlet. If you curve and then stay straight for a reasonable amount of distance (who knows what that is) it will probably be effective.
I was thinking of a long velocity stack, but with a "scoop" that caught some more air from the underside. Kind of like a cornucopia with the one side extended (or like that sport where they fling the ball around).
Old Jun 20, 2003 | 06:00 AM
  #35
DC2R714's Avatar
Default Re: Velocity stack for turbo (ricodemus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricodemus &raquo;</TD></TR><TR><TD CLASS="quote">
(or like that sport where they fling the ball around).</TD></TR></TABLE>
Jai lai (sp?)
Old Jun 20, 2003 | 06:32 AM
  #36
ricodemus's Avatar
Jai lai (sp?)</TD></TR></TABLE>
yeah, however you say it/spell it
Old Mar 1, 2005 | 05:59 PM
  #37
SSBPGSR's Avatar
high lie! haha, great thread. id like to know more about the distance of the intake tube off the compressor housing, i have a 4 inch inlent on my turbo, need help with an intake on it lol. just a 4 inch tube straight out with a filter on it would do i suppose? or maybe if i fabbed something where there would be stages of mesh screen, to make a total of 5 layers of mesh screen? something similar to this..
====|====|====|==== (velocity stack here) maybe a total of 10-12inches of piping?
with each | representing a mesh screen filter. and the == representing a 4 inch tube. im just tryint ot think of ways to keep the turbine safe and get as much air into the turbo as possible..safely. id like this thread to grow more, gaining interest in the velocity stacks
Old Mar 1, 2005 | 06:06 PM
  #38
wantboost's Avatar
Who is Mr Robot?
Default Re: Velocity stack for turbo (SSBPGSR)
1 single screen flows less than one proper filter, so but putting 4 of those inside a tube you are bascially hitting your turbo in the nuts, its not gonna do **** but complain and have poor spool characteristics
Old Mar 1, 2005 | 06:13 PM
  #39
Blaze45's Avatar
Brrraaaap!
Default Re: Velocity stack for turbo (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">1 single screen flows less than one proper filter, so but putting 4 of those inside a tube you are bascially hitting your turbo in the nuts, its not gonna do **** but complain and have poor spool characteristics</TD></TR></TABLE>
Wait I thought that the people who ran/running mesh screens are getting better spool up times then people with the proper filters? Any one care to explain?
tia
Blaze
Old Mar 1, 2005 | 06:41 PM
  #40
SSBPGSR's Avatar
Default Re: Velocity stack for turbo (Blaze45)
yea thought it flowed more than an air filter? just looking for ideas to run an intake tube on the S housing
Old Mar 1, 2005 | 06:44 PM
  #41
wantboost's Avatar
Who is Mr Robot?
go back and read the whole thread. Screens take up a lot of the available surface area on the compressor inlet, air doesnt flow too well through solid material, combine that with the fact that the screen wire is curved, which causes the air to tumble around as is enters the turbo.
A screen on the otherhand, while it would appear that it would choke the turbo, most if the available surface area is in fact permeable not solid like a screen, that is, air can flow through it.
Old Mar 1, 2005 | 07:00 PM
  #42
Blaze45's Avatar
Brrraaaap!
Is this with or with out a velocity stack? Also Im wondering, since the inlet on the turbo is the same size(lets say 2in), does it really matter if the screen is on there vs. having a filter(the air is going to be sucked in eathier way) I mean, can the turbo suck in more air then the inlet can keep up with? Sorry if thats confusing. Also, what do you mean by tumble? Wouldnt the flow through the charge piping cause the air to tumble/be disrupted anyways?
Sorry for the threadjack Boostedhybrid....
  #43
SSBPGSR's Avatar
good thoughts..
Old Mar 1, 2005 | 07:26 PM
  #44
wantboost's Avatar
Who is Mr Robot?
well, if you are just running something directly off of the turbo, then id say the whole tumbling effect cant be fixed. The nice thing about having a length of pipe before the compressor inlet is that the piping gives the flow of air the time to smooth and and have a more laminar flow.
Old Mar 1, 2005 | 07:39 PM
  #45
Blaze45's Avatar
Brrraaaap!
Looked up laminar and this is what is said: A thin plate, sheet, or layer. Is the definition that we have been using or is it something different? Sorry for my stupidness.
Old Mar 1, 2005 | 07:47 PM
  #46
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sure he won't mind, seeing as this thread is from like 3 years ago! lol
Old Mar 1, 2005 | 08:42 PM
  #47
Blaze45's Avatar
Brrraaaap!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Looked up laminar and this is what is said: A thin plate, sheet, or layer. Is the definition that we have been using or is it something different? </TD></TR></TABLE>
Anyone?
Old Mar 1, 2005 | 08:48 PM
  #48
wantboost's Avatar
Who is Mr Robot?
I'd try to explain it, but im running on 3hrs of sleep so maybe tomorrow when my brain is functioning
Old Mar 1, 2005 | 09:05 PM
  #49
Si Shane's Avatar
think linear. Straight line. smooth laminar flow means that the air doesn't get caught in eddys and ****. just constant flow in one direction.
Old Mar 1, 2005 | 09:10 PM
  #50
wantboost's Avatar
Who is Mr Robot?
Default Re: Velocity stack for turbo (Si Shane)
thank you, you defined it for me
slayer423
Dec 18, 2012 02:13 PM
touny1979
Apr 25, 2007 06:33 AM
chasemyhonda
Oct 22, 2006 12:33 PM
xenocron
Dec 18, 2003 10:48 AM
elas9394
22
Dec 9, 2002 01:14 PM
