gm 3 bar map sensor help!?
Old Feb 26, 2008 | 09:00 AM
soulo's Avatar
Default gm 3 bar map sensor help!?
I have a civic turbo and want to put a 3bar map sensor. My wire are:
yellow/white
yellow
green/white
which output goes where to the gm?
A B C
I looked on hondata site but they have different color wire which is:
Yellow/white
White
Red
any clue? please help!!!
Old Feb 26, 2008 | 10:28 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: gm 3 bar map sensor help!? (soulo)
what chassis do you have? im being lazy today. or get a volt meter, key on, the one with 5 volts goes to pin c, the one that has continuity to ground, goes to pin a, the last one has to be the signal wire that goes to pin b.
Old Feb 26, 2008 | 11:56 AM
soulo's Avatar
Default Re: gm 3 bar map sensor help!? (boostedcivicsir)
i have a 92 civic hb SI with GSR OBD1 swap
Old Feb 26, 2008 | 12:49 PM
Mr. Badwrench
if you used the 92 civ harness, your wires should be:
yellow/red
white
green/white
yellow/red (or yellow/green) is 5volt reference
green/white is ground
leaving the last as the signal.
unless the helms is wrong or the claratin is messing with me.
Old Feb 26, 2008 | 11:46 PM
soulo's Avatar
not sure because i bought the car swap.
Old Feb 27, 2008 | 06:09 AM
slow96coupe's Avatar
grab a volt meter... like he said above... that is the for sure way to get it
Old Feb 27, 2008 | 09:03 AM
boosted k20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulo &raquo;</TD></TR><TR><TD CLASS="quote">I have a civic turbo and want to put a 3bar map sensor. My wire are:
yellow/white
yellow
green/white
A B C
Yellow/white
White
Red
yellow/white ----&gt; C Power
yellow ----&gt; B Signal (you color should be white, maybe the white wire faded to yellow)
green/white ----&gt; A GND
B18EG6
Mar 28, 2007 12:36 PM
I B BANGGIN
Feb 6, 2007 07:50 PM
x-1
May 27, 2005 10:51 PM
ItsStockOfficer
Apr 8, 2005 08:27 PM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
