vafc haven't seen this answerd.
Old Nov 3, 2003 | 04:58 AM
Snail Tuning's Avatar
Default vafc haven't seen this answerd.
ok i keep getting code 3 map sesnor with my vafc.
what should i have the inputs and outputs set at?
i am running a vafc on a d15b nonvtec with 7psi on an ihi turbo.
should it be 5 in 5 out be cause i have no vtec wires hooked up?
also what is the VTM sensor? i need some info on that to make sure its not the problem. thanks
92 civic sedan. stock ecu, dsm450 injectors ihi turbo.
Old Nov 3, 2003 | 07:57 AM
InTeGrA B18b1's Avatar
Default Re: vafc haven't seen this answerd. (bmcc72)
6 in, 6 out
Old Nov 3, 2003 | 08:05 AM
reaction360's Avatar
do not hook up the vtm wire if you're not running vtec. vtm is only for vtec motors. i found this out when i wired up my afc using a vafc wiring diagram. everything else is the same. i'm running a safc on my b16a, so i need to find me a vafc. hope this helps
Old Nov 3, 2003 | 10:50 AM
Default Re: vafc haven't seen this answerd. (reaction360)
should i reatach the vtm wire to the ecu then? 6in 6out vtm hooked back to the ecu should fix my code 3 and allow the car to run better?
Old Nov 3, 2003 | 06:06 PM
help me out. i reatached the vtm and switched to 6 in and 6 out car would stall and not run for **** help me out.
Old Nov 3, 2003 | 06:39 PM
MADEINIRAQ's Avatar
i threw map code at 9pis with -35% .. -36% and no code
Old Nov 3, 2003 | 07:32 PM
Default Re: vafc haven't seen this answerd. (madeiniraq)
ok well i switched to 6in 6out and things seemed to run alittle better in the higher rpms but it won;t idle at all. any sejestions?
im now at -36% at idle and it idles ok fairly steady but sometimes it jumps around and then it will stall.
Old Nov 4, 2003 | 07:18 AM
6 in 6 out fixed the code but the car still idles really bad.
any sejestions?
Old Nov 4, 2003 | 09:02 AM
platinum00's Avatar
so the car runs fine now. just does nto idle right . correct. ?
mess with you 1k settings. i had mine set to -46 at idle. do you have an a/f gauge. what is it telling you..
im assuming your running the stock map sensor..
platinum.
Old Nov 4, 2003 | 11:10 AM
Happyman's Avatar
Default Re: vafc haven't seen this answerd. (platinum00)
I have my car -40 across the board and I idle good(a little rich but im not complaining) and I run a little rich throughout the rpm. Good times though with the afc hack :-P
Old Nov 4, 2003 | 06:18 PM
well when i had the vafc set at 4 in 4 out my idle was at -50 and i was still rich but it idled smooth.
now at 6in 6out it bounces around alot and i have to keep it at -35% to keep it from stalling. its really really rich at -35. any sujestions?
should i buy a fuel pressure regulator and drop my pressure some?
topsekret
Dec 22, 2002 05:49 PM
.Beaver
28
Nov 19, 2002 04:31 PM
PrecisionH23a
Sep 17, 2002 10:24 AM
