vafc trouble throwing code 22
Old Dec 22, 2002 | 01:52 PM
topsekret's Avatar
Default vafc trouble throwing code 22
need help figureing out what it is that is causing this i already tried every possible way vtm wire no vtm wire please help so i can have my car on the street
Old Dec 22, 2002 | 02:13 PM
AzG35's Avatar
Default Re: vafc trouble throwing code 22 (b18vtec)
Check the grounds, and also check to see if the VTEC wires are backwards or not. That happens occasionally. Make sure all your connections are good too, solder is your friend.
Old Dec 22, 2002 | 04:49 PM
topsekret's Avatar
Default Re: vafc trouble throwing code 22 (AzSi22)
still thorwing the code i could it be from a bad ground on my auxilary harness if so please help i ran the wires and it still gives a code for vtec oil pressure
Old Dec 22, 2002 | 05:36 PM
uNF$@#!'s Avatar
its your wiring. AzSi22 already told you this.
why the hell do you ask for help if you dont listen?
we can't pinpoint the problem for you online.
if you dont feel like you are competant enough to do it, tow it into a shop and have them do it for you.
installing a VAFC REALLY isnt rocket scientry.
Old Dec 22, 2002 | 05:49 PM
topsekret's Avatar
Default Re: vafc trouble throwing code 22 (Soup ****)
it really isnt the vafc anymore i think my ecu is bad its still giving me those codes i dunno but u know i dont listen to directions well so im not sure but its still has the codee 22 even with the vafc taken out
chulopilong
Mar 19, 2005 09:39 AM
97dc2
Sep 19, 2004 08:54 PM
pbizzlegsr
Mar 8, 2004 04:33 PM
.Beaver
28
Nov 19, 2002 04:31 PM
