VAFC hack w/ 720cc injectors = able to boost more?
if i swapped my 440cc's for 720cc's and did the proper adjustments (don't have the time to figure it out, i'm at work ) then i.e. can't i run it at -50% through -45% and be able to boost more without the map sensor reading it?
Re: VAFC hack w/ 720cc injectors = able to boost more? (sgT)
what's size injectors are the biggest you can idle off of? just curious
[Modified by 98civicEX, 6:32 PM 6/28/2002]
Re: VAFC hack w/ 720cc injectors = able to boost more? (98civicEX)
I think the largest are 440/450cc injectors. it just works out with 10psi and the afc setting.
1.8T_EG
12-09-2003 09:11 PM
