VAFC hack
Old Feb 17, 2003 | 07:45 AM
B20-T's Avatar
Default VAFC hack
Anyone know a good site where it show me how to use the vafc hack.I am running on 370cc injectors..plmk thanks
Old Feb 17, 2003 | 07:58 AM
zojirushi's Avatar
Default Re: VAFC hack (B20TURB0)
http://www.thedropshop.tv/vafc.htm
Old Feb 17, 2003 | 08:04 AM
Smashback's Avatar
You'll need 450s, it absolutely will not work with 370cc.
Old Feb 17, 2003 | 08:12 AM
zojirushi's Avatar
Default Re: VAFC hack (Hatchblack)
i use 370's
Old Feb 17, 2003 | 08:42 AM
Smashback's Avatar
Default Re: VAFC hack (zojirushi)
With how much boost?
Old Feb 17, 2003 | 09:35 AM
zojirushi's Avatar
.45 bar
Old Feb 17, 2003 | 09:54 AM
Smashback's Avatar
Well that explains it..I couldn't even run 7 PSI on mine without 450s.
Old Feb 17, 2003 | 10:05 AM
zojirushi's Avatar
.45 is around 7psi..
huh?
only way i'm running the hack on 370's is cuz i raised my fuel pressure.
Old Feb 17, 2003 | 10:41 AM
rioninja's Avatar
hack should be good for 5psi on the 370s, if you calculate it.
Old Feb 17, 2003 | 11:07 AM
Smashback's Avatar
Yeah technically it's like 6.5 psi BUT...are you running a .45 bar spring but is the MAP actually seeing that much...either way, I'd throw a code the second I hit 7 PSI.
Old Feb 17, 2003 | 11:20 AM
zojirushi's Avatar
o
what were your settings on the afc?
Old Feb 17, 2003 | 11:21 AM
Smashback's Avatar
It was about a year ago..I can't remember what happened yesterday, much less what I did back then as a matter of fact, what were we talking about?
swlabhot's Avatar
So u were running 370cc and got a code at 7psi?
Old Feb 17, 2003 | 11:26 AM
zojirushi's Avatar
Default Re: VAFC hack (swlabhot)
i'm not getting any codes
Old Feb 17, 2003 | 11:31 AM
swlabhot's Avatar
What are your AFC settings??
Old Feb 17, 2003 | 11:38 AM
zojirushi's Avatar
-33% across
my idle fuel pressure with vacume is 44 psi
Old Feb 17, 2003 | 11:43 AM
Sivik's Avatar
this is a good site for the "hack:"
http://www.geocities.com/thermalfid16/VAFChack1.html
Old Feb 17, 2003 | 12:42 PM
zojirushi's Avatar
Default Re: VAFC hack (Sivik)
website doesn't work
Old Feb 18, 2003 | 01:30 PM
Sivik's Avatar
it just worked for me
Old Feb 18, 2003 | 03:47 PM
rcsivtec07's Avatar
can you run bigger injectors than 450cc
Old Feb 19, 2003 | 08:30 PM
Sivik's Avatar
Default Re: VAFC hack (rcsivtec07)
i'm sure you could run as big as you like, just make sure you compensate for the larger injectors with the settings. I have not done this yet so I'm clueless on how to adjust it. I can only read what someone else has written and learn from that.
Old Mar 16, 2003 | 09:05 PM
skud_dusty's Avatar
to my understand the biggest you can go is about 550's, and then you'll start running into idle issues.
with 440's/450's or wahtever the first gen dsm injectors are, you're good till about 11 or 12 psi, then you'll throw a code. the smaller the injector, the less psi you'll be able to run without throwing a code
all an ecu does it look at the pressure in the intake manifold, and figures out how much fuel to dump in. when using that big of an injector, you adjust the signal that the ecu is getting into thinking that there is a lot less pressure than before, but you'll still be dumping in enough fuel as it had stock.
the beauty in all this is you can keep the manifold pressure quite low, while dumping in a lot more fuel, allowing you to run a turbo.
*edit* dammit back from the dead...my bad
[Modified by skud_dusty, 10:06 PM 3/16/2003]
T3T495GSR
Jul 25, 2003 12:48 PM
SlamMan
Jun 16, 2003 09:54 PM
reditr
Jun 8, 2003 04:01 AM
seanjohn81
Feb 26, 2003 02:19 PM
98civicEX
Aug 5, 2002 01:48 PM
