VAFC hack
.45 is around 7psi..
huh?
only way i'm running the hack on 370's is cuz i raised my fuel pressure.
Well that explains it..I couldn't even run 7 PSI on mine without 450s.
Yeah technically it's like 6.5 psi BUT...are you running a .45 bar spring but is the MAP actually seeing that much...either way, I'd throw a code the second I hit 7 PSI.
what were your settings on the afc?
i'm sure you could run as big as you like, just make sure you compensate for the larger injectors with the settings. I have not done this yet so I'm clueless on how to adjust it. I can only read what someone else has written and learn from that.
to my understand the biggest you can go is about 550's, and then you'll start running into idle issues.
with 440's/450's or wahtever the first gen dsm injectors are, you're good till about 11 or 12 psi, then you'll throw a code. the smaller the injector, the less psi you'll be able to run without throwing a code
all an ecu does it look at the pressure in the intake manifold, and figures out how much fuel to dump in. when using that big of an injector, you adjust the signal that the ecu is getting into thinking that there is a lot less pressure than before, but you'll still be dumping in enough fuel as it had stock.
the beauty in all this is you can keep the manifold pressure quite low, while dumping in a lot more fuel, allowing you to run a turbo.
*edit* dammit back from the dead...my bad
[Modified by skud_dusty, 10:06 PM 3/16/2003]
T3T495GSR
Jul 25, 2003 12:48 PM
reditr
Jun 8, 2003 04:01 AM
seanjohn81
Feb 26, 2003 02:19 PM
98civicEX
Aug 5, 2002 01:48 PM
as a matter of fact, what were we talking about?
