VAFC + 450cc DSM
Old Dec 27, 2002 | 12:16 AM
C ronic's Avatar
Default VAFC + 450cc DSM
Need some help here... I read the writeup, I believe I have this setup correctly, but she bucks like it's getting too much fuel, and idles like isht.
bounces from 900-1300rpm.
Any clues?
Old Dec 27, 2002 | 01:43 AM
First Gen Man's Avatar
Default Re: VAFC + 450cc DSM (C ronic)
sup man.. i have the same problems but im running dsm 390cc .. do u have the sensor type IN 06 out 06 and if running the vafc hack throttle %'s should be . low98% hi 99%
Old Dec 27, 2002 | 06:00 AM
RAWB's Avatar
Sounds like your RICH, what's your 1K RPM Fuel setting at? Start from 40% and work your way up, 35, 30%, etc.
Also, what's your FUEL pressure at the rail?
Old Dec 27, 2002 | 07:54 AM
C ronic's Avatar
Default Re: VAFC + 450cc DSM (integracon)
Pressure @ rail (from guage) is 52psi. I cannot get it any lower, since the install of my Walbro 255. I am set at 71%/72% throttle. I am -45 for 1000rpm, then -35, -35, -35, -40, -40, -40, -40. For both low and high.
Old Dec 27, 2002 | 08:26 AM
RAWB's Avatar
Try -50% at 1K RPM.
If that doesn't work, your going to have to lower that rail pressure- 450's at 52psi is dumping too much FUEL. Try doing the "Drill holes in your FPR" trick.
Old Dec 27, 2002 | 09:20 AM
C ronic's Avatar
What is this drilling holes trick?
Is there a write up on it somewhere or can you explain to me how I do it?
Old Dec 27, 2002 | 09:24 AM
RAWB's Avatar
CLICK HERE
Old Dec 30, 2002 | 12:49 AM
C ronic's Avatar
You rock, will be trying this tomorrow.
Hoodwinked
Sep 3, 2003 08:30 PM
platinum00
Jun 11, 2003 06:13 PM
GOKOU
Aug 7, 2002 12:38 PM
GReddyB18C
Jul 18, 2002 01:56 PM
inspyral
Jul 7, 2002 03:18 AM
