VAFC-2 hack?? On i-vtec??
Old Apr 30, 2004 | 12:09 PM
tougeEGsies's Avatar
Default VAFC-2 hack?? On i-vtec??
Has any one tried the afc hack on a vafc-2? Will it work with i-vtec on an 02 si, looking to only boost 7 psi, uprade injectors, etc,etc, only concern is fuel management. Any info would be appriciated.
Modified by 909 Civic at 4:06 PM 5/2/2004
Old Apr 30, 2004 | 02:32 PM
Default Re: VAFC-2 hack?? On i-vtec?? (909 Civic)
Old Apr 30, 2004 | 04:24 PM
Stewie's Avatar
I don't see why it wouldn't
Old Apr 30, 2004 | 06:29 PM
perlmeister8's Avatar
I am running the hack with a safc2 and have seen people run the hack with a vafc so it will work. Regarding the i-vtec, in the safc2 instuction manual it shows wiring diagrams for the 02 si.
Old Apr 30, 2004 | 06:33 PM
Muckman's Avatar
Moderator in Chief
Default Re: VAFC-2 hack?? On i-vtec?? (perlmeistere81)
I thought the ivtec was hard to hack and so forth...
I bet it doesnt work.
Old Apr 30, 2004 | 07:24 PM
Joseph Davis's Avatar
Default Re: VAFC-2 hack?? On i-vtec?? (Muckman)
It's what Cybernation does, or at least their black box piggybacks with the AFC to modify MAP sensor signal - I don't see any other way they get the stock ECU not to freak out under boost, do you? Black box just offsets the MAP signal to a certain point so that people don't look at the AFC settings and go "oh, it's just an AFC hack"
If you've ever seen or installed one of Cybernation kits... might not be a good thing to copy *anything* they do.
Old Apr 30, 2004 | 08:07 PM
thanx for the info,but has any one done it an ep3??
Old May 2, 2004 | 03:05 PM
bump
CRneXt
Apr 3, 2003 04:01 PM
Boostless97Lude
Sep 6, 2002 02:11 PM
filetofit
Sep 4, 2002 11:30 AM
Jockobo
Jun 25, 2002 09:19 AM
Slater
Jun 11, 2002 08:02 AM
