Vacuum source for 3 bar map sensor?
Old Sep 11, 2002 | 05:34 PM
94cxhybrid-T's Avatar
New User
Default Vacuum source for 3 bar map sensor?
Is there a partucular vacuum source i should use or can i just tee off any from the manifold.
Thanks
Mike
Old Sep 11, 2002 | 05:35 PM
dustin's Avatar
Default Re: Vacuum source for 3 bar map sensor? (94cxhybrid-T)
vacuum is vacuum
Old Sep 11, 2002 | 06:01 PM
New User
Default Re: Vacuum source for 3 bar map sensor? (dustin)
thanks, not thinking today
Old Sep 11, 2002 | 06:40 PM
b18bturbo's Avatar
i woudl use something that is not teed allready the map is very critical in setups.
Old Sep 11, 2002 | 06:43 PM
ekb18c's Avatar
Default Re: Vacuum source for 3 bar map sensor? (b18bturbo)
Yup!! Take it directly from the intake manifold!
Old Sep 11, 2002 | 08:25 PM
shadowdawn's Avatar
Default Re: Vacuum source for 3 bar map sensor? (ekb18c)
wait a minute..... if you get a 3bar MAP SENSOR, wouldn't you simply take your stock one off and put this one in its place.... its job is to sit on a hole in the IM to get pressure reading...
I know I'm wrong here but that just makes sense to me, just englighten me please
Old Sep 11, 2002 | 09:35 PM
Brian_92GSR's Avatar
New User
Default Re: Vacuum source for 3 bar map sensor? (shadowdawn)
It doesn't fit there. It has a nipple to run a vacuum line to.
Old Sep 11, 2002 | 10:17 PM
boostaholic's Avatar
Default Re: Vacuum source for 3 bar map sensor? (Brian_92GSR)
I tapped a new nipple in my intake manifold for the 3bar map sensor and just ran tee's for everything else off the FPR vacuum source.
tony_2018
May 25, 2014 06:48 PM
tempsohc
Jun 19, 2011 06:06 PM
Topdawgg
Jun 25, 2007 10:02 AM
mike93boost
Jun 19, 2006 05:43 PM
fast93accord
May 23, 2005 09:31 AM
