GM 3 bar map sensor
Old Jun 18, 2006 | 12:12 PM
mike93boost's Avatar
Default GM 3 bar map sensor
would it be okay to run a hose from the 3 bar map sensor to my golden eagle vacuum manifold which is right next to it or is that too many "T" 's for the map sensor?
Old Jun 18, 2006 | 03:38 PM
B18 CYA's Avatar
yup thats how I run my map sensor and works perfectly fine
Old Jun 18, 2006 | 03:39 PM
platinum00's Avatar
Default Re: GM 3 bar map sensor (mike93boost)
If your using the golden eagle vacuum manifold you shouldnt have any T's.
The vac manifold has what, 6 ports maybe. Are you using all of them already?
platinum
Old Jun 18, 2006 | 04:51 PM
Default Re: GM 3 bar map sensor (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">If your using the golden eagle vacuum manifold you shouldnt have any T's.
platinum</TD></TR></TABLE>
well the vacuum manifold is T'd of the brake booster line so there are T's.. and then everything else is connected to the vacuum manifold.
i heard you should hook the map sensor up to its own spot on the intake manifold and not where theres a bunch of T's.
Old Jun 18, 2006 | 04:54 PM
TypeSLO's Avatar
i have a billet aluminum piece made by LHT Performance. it screws into where the stock map sensor goes on the TB and has a nipple coming out of it. hook up my MSD map sensor there. $20 and blingin.
Old Jun 18, 2006 | 05:04 PM
platinum00's Avatar
If you run the line of the vac manifold that is T'ed to the brake booster line you will be fine. That brake boosted line can hold alot. I have 6 or 7 things hooked to it with no problem at all.
platinum.
Old Jun 18, 2006 | 05:51 PM
Default Re: GM 3 bar map sensor (TypeSLO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSLO &raquo;</TD></TR><TR><TD CLASS="quote">i have a billet aluminum piece made by LHT Performance. it screws into where the stock map sensor goes on the TB and has a nipple coming out of it. hook up my MSD map sensor there. $20 and blingin. </TD></TR></TABLE>
this at the bottom? thats pretty nifty.
http://www.lhtperformance.net/....html
Old Jun 18, 2006 | 05:58 PM
Joseph Davis's Avatar
I'd go that route. MAP should be far away from an extraneous pressure fluctuations, and the stock feed is adequately isolated + baffled.
PS - the poorboy route is to epoxy a plastic barb nipple into that port. The poorboy-trying-to-get-rich route is where you go trolling for high-dollar riceboys and money races by stuffing Motorola 2.5 bar into the stock MAP enclosure. The tards never catch on to that one.
Old Jun 19, 2006 | 07:24 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">If you run the line of the vac manifold that is T'ed to the brake booster line you will be fine. That brake boosted line can hold alot. I have 6 or 7 things hooked to it with no problem at all.
platinum.</TD></TR></TABLE>
I used the nipple on my stock Y8 intake manifold that used to be for the PCV system to run my vacuum manifold. It's actually the same I.D. as the brake booster.
Old Jun 19, 2006 | 08:45 AM
TypeSLO's Avatar
Default Re: GM 3 bar map sensor (RyanCivic2000)
go with the LHT piece. it's the hotness.
Old Jun 19, 2006 | 09:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSLO &raquo;</TD></TR><TR><TD CLASS="quote">go with the LHT piece. it's the hotness. </TD></TR></TABLE>
i did.. ordered last night.
Old Jun 19, 2006 | 02:37 PM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I used the nipple on my stock Y8 intake manifold that used to be for the PCV system to run my vacuum manifold. It's actually the same I.D. as the brake booster.</TD></TR></TABLE>
the one on the back of the IM? i cant remember what i did with that port now that you mention it.
platinum.
Old Jun 19, 2006 | 02:56 PM
RyanEJ8's Avatar
No it's a big one on the front of the intake manifold.
Old Jun 19, 2006 | 03:04 PM
platinum00's Avatar
i just looked. i have that one just blocked off. i had no idea it was the same size.
good info as always Ryan
platinum.
Old Jun 19, 2006 | 03:21 PM
vietjdmboi's Avatar
here is my car with the lht piece..
Old Jun 19, 2006 | 05:43 PM
drumking15's Avatar
Default Re: GM 3 bar map sensor (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">
PS - the poorboy route is to epoxy a plastic barb nipple into that port. The poorboy-trying-to-get-rich route is where you go trolling for high-dollar riceboys and money races by stuffing Motorola 2.5 bar into the stock MAP enclosure. The tards never catch on to that one. </TD></TR></TABLE>
nifty
tony_2018
May 25, 2014 06:48 PM
tempsohc
Jun 19, 2011 06:06 PM
Topdawgg
Jun 25, 2007 10:02 AM
88 rex
Aug 16, 2005 06:49 PM
94cxhybrid-T
Sep 11, 2002 10:17 PM
