vacuum lines too long for a manual boost controller? MBC
i know you want the shortes vac. lines as possible, but would it be bad to extend them so long that you can adjust your boost controller from inside the car?
I dont see why you couldnt and Imma bump this bitch because thats a dam good idea, no need to get out of the car, pop the hood on the side of the road, turn, boost, get out adjust blah blah
Can just get Cathy to do it since shes down tehre anyways
Giddy up
Giddy up
usually they say longer lines from the WG is bad and will cause bleeding off boost or spiking. I kept mine short and put the MBC like right next to my intake. Prob not even a foot off the turbo
you can buy a cable that runs to the cockpit so that you can keep the vacuum lines short!
http://www.hallmanboostcontroller.com/
I think Only Hallman makes that for their kits.
I run a dual stage MBC. When I want higher boost i just hit the button to raise it where I have it set to. Worksnice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Dan »</TD></TR><TR><TD CLASS="quote">you can buy a cable that runs to the cockpit so that you can keep the vacuum lines short!
http://www.hallmanboostcontroller.com/</TD></TR></TABLE>
i know they sell it.. it is also twice the price i got my boost controller for....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">i have heard it does. I try and keep them as short as possible. </TD></TR></TABLE>
i want to keep it short as possible because of the change in pressure to move the ball inside... so i'm going to keep it near the radiator support i guess... (somewhere as close as possible) that's why i want the cable.
I say someone tries it and posts up what happens
To many "i heard...." Hell if i had my **** right now I would try it. Im lazy so if i could change the boost inside the car that would be
