Which vac. source is more accurate?
Old Nov 18, 2005 | 06:20 PM
RNPoo7's Avatar
Default Which vac. source is more accurate?
So I finally got my new boost controller in today and was going to install it but I came across a question
Anyway, which is more an accurate source for the vacuum reading?
Should I get a reading to the boost controller from my vacuum manifold - hooked up to my brake booster
or
Should I connect it to my turbo compressor?
TIA
Old Nov 18, 2005 | 06:44 PM
Muckman's Avatar
Moderator in Chief
Default Re: Which vac. source is more accurate? (RNPoo7)
Both offer "accurate" readings, just from different spots on the system. There will always be a pressure drop from the intercooler and piping.
I think what you after is you want to know the exact amount of boost entering the engine, which would mean you should use the intake manifold/brake booster sources.
Old Nov 18, 2005 | 07:29 PM
RNPoo7's Avatar
oh ok
Old Nov 18, 2005 | 08:06 PM
miro_gt's Avatar
Default Re: (RNPoo7)
I connected mine to the FPR hose with a tee ... where I got connected the BOV and the boost gauge as well ... everything works fine
Old Nov 18, 2005 | 09:09 PM
vaporboy12's Avatar
Default Re: (miro_gt)
i got my boost controller before the intercooler and boost gauge after off the intake mani.
Old Nov 18, 2005 | 09:20 PM
Def's Avatar
Def
Your compressor never goes below ambient pressure(at least not like you're thinking).
b18BoostedDC2
Jul 30, 2005 01:42 PM
99teggsr
Jun 1, 2005 09:39 PM
RNPoo7
Apr 8, 2005 06:33 AM
ludelvr
Aug 25, 2002 10:40 PM
TurBoXBirD16
Feb 10, 2002 10:20 AM
