Not boosting all the way
Old Apr 6, 2005 | 04:29 PM
RNPoo7's Avatar
Default Not boosting all the way
I'm only boosting 6 psi (size of my wg spring) instead of 10 psi through the boost controller.
Set up
Tial 38mm wg
small red spring (5.xx) psi
Greddy Profec B spec II
Golden Eagle vacuum manifold
HKS SSQ bov
Autometer boost gauge
vaccum lines
Wastegate:
Top port is going to 'COM' niddle on the boost controller solanoid
Side port is T' ed to the vaccum 'NC' Line from teh boost controller to the compressor housing
Actual boost controller unit vacum line is going to the vacuum manifold
Boost controller connections:
'COM' port is going to the Top port of the wg
'NC' is going to the turbo compressor housing
Vacuum manifold connections:
Tapped into the brake booster
BOV & boost gauge:
Both are going to the vacuum manifold.
This is the way I had a month ago and it worked. I turned "off" the boost controller till I get a chance to go tune. When I went to go tune this past weekend, I turned on the boost controller, and it kept on staying at ~6 psi. Same settings as when I had it working before.
Any idea/suggestions/comments are welcomed.
Thanks
Modified by RNPoo7 at 9:20 AM 4/7/2005
Old Apr 6, 2005 | 04:41 PM
Evanmb44's Avatar
make sure all the connections are good and there are not any leaks somewhere
Old Apr 6, 2005 | 05:20 PM
Rod.'s Avatar
Default Re: (Turboaddict)
like he said check any possible leak
Old Apr 6, 2005 | 05:32 PM
RNPoo7's Avatar
I did, no leaks
Old Apr 6, 2005 | 06:56 PM
Na-Spirit's Avatar
manifold cracked? atleast thats what happend with me, wg loose? ya you can tell how good my setup was.
Old Apr 6, 2005 | 06:59 PM
RNPoo7's Avatar
Default Re: (mugenknockoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenknockoff &raquo;</TD></TR><TR><TD CLASS="quote">manifold cracked? atleast thats what happend with me, wg loose? ya you can tell how good my setup was.</TD></TR></TABLE>
I don't think so, at least doesnt look like it.
btw: it's a log style lovefab manifold
Old Apr 7, 2005 | 07:26 AM
RNPoo7's Avatar
No luck yet.
Old Apr 7, 2005 | 08:56 PM
Evo-man@20psi's Avatar
Default Re: Not boosting all the way (RNPoo7)
Boost leak
Old Apr 8, 2005 | 04:17 AM
RNPoo7's Avatar
Default Re: Not boosting all the way (Blue00vtecsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue00vtecsi &raquo;</TD></TR><TR><TD CLASS="quote">Boost leak </TD></TR></TABLE>
Any ideas where?
My guess is that the line from the Greddy boost controller unit inside the car. It has a vacuum line that goes to the vaccum manifold. I am guessing that line broke or something through the firewall.
Old Apr 8, 2005 | 06:33 AM
2000GSRT's Avatar
ericstambaugh07
Jun 23, 2007 09:04 AM
faSHOwidIT
Jan 31, 2007 03:59 PM
swappedcx
Aug 16, 2006 03:04 PM
pip9
Sep 24, 2004 09:17 AM
importboi22
May 20, 2004 04:43 AM
